2wd Cossy Engine Life
How many miles would you expect a Standard 2wd cossy engine to do before it is in need of e rebuild. I am about to buy to 3 door, completely standard, but the engine has done 91k, good service history and runs well. Will it need a rebuild soon? I have no plans for big BHP, just leave it as I get it standard.
Thanks for all your advice.
depends mate...
how hard has it been driven?
how many cold starts etc?
have seen cossies do 125k without a rebuild.
it also depends alot on how you will drive it?
any problems with oil burning etc will only really be shown up if you drive the car relitivley hard.
if you just cruise around using no boost the engine will last forever.
my car had only done 67k when i bought it but as soon as i chiped it and turned boost up ot was evident that it needed a rebuild.
some engines are better than others as all cossie yb unit were hand built.
some engine builders were better than others.
Hard to say, depends on what you want..
If you're gonna rebuild, it's smart to think about future plans,
don't wanna do it again
Give the guys at A1 a call, they build good engines (So i've heard)
I have seen a 240,000mls std engine that had only had a head rebuild.
Mind you it was rattling like a good un when came in for a quote.
The engine was std and had only had regular oil changes but had a auto box attached for a disabled driver so maybe it had never done any "real work"
The car was certainly showing its mileage aswell.
Originally Posted by PAULDPALMER
how much would it cost for a standard rebuild?? im buying a cossie in 2-3 monts time and this issue concerns me aswell
mine dun 118k on a stage 3,then lost oil pressure due to the oil pump drive wearin out,as 4 a rebuild ave a go ur self if ur handy wiv the spanners an know wot ur doing shudnt cost no more 1500-2000 dependin on wot u need. me an my m8 rebuilt mine wiv out any probs,to be honest there a pretty easy engine to work on if u ask me,cant wait to build my nxt 1.
Originally Posted by cossy2wd
just had mine rebuilt original old engine had done 126thousand running 300bhp then all of a sudden it spun a shell on no 3 so that was that.
What happened when the bearing spun ? did the motor seize ?
Thanks.
Thanks.
rog
Sep 4, 2015 12:10 PM
lockie
Jul 31, 2015 10:03 PM
