Mondeo Flywheel and clutch on a fiesta?
Old Mar 13, 2006 | 09:52 AM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Default Mondeo Flywheel and clutch on a fiesta?
Is a mondeo flywheel bigger than a fiesta one and will it a fiesta??
Im just thinking if its bigger and fits i can fit a mondeo clutch which will have more surface area so will be better in theory
anyone know??
Old Mar 13, 2006 | 09:56 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
it will go on mate, but you will need a MTX75 gearbox.
its a 240mm clutch compared to the std 220mm item.
but a good RS turbo clutch will do (std 220mm size)
Old Mar 13, 2006 | 10:08 AM
Sunil_FiestaRS1800
cheers mate. so it wont work with my CTS box then cause that ib5 i think ?
Just trying to get the car sorted for a brunters thrash in april.
Think im just gonna stick a std rsturbo clutch in with a std fiesta flywheel then as ive fucked two alcon six paddles so far in a very short space of time. The first one the clutch was fucekd to begin with (manfacturating fault) but second seemed fine for a while then just let go. Could be down to my lightened flywheel somehow? although i did have it re faced before fitting the clutch.
Old Mar 13, 2006 | 04:07 PM
Badman38's Avatar
Badman38
ap all the way i dont rate alcon clutches for fwd application they just dont last, ap four paddle with there new heavy duty cover 3560-2 will handle 350bhp then after that got to be a twin plate paddle but in the mean time a standard rs turbo clutch should do the job nicely...
i'll see you @ the thrash
Old Mar 13, 2006 | 04:10 PM
Sunil_FiestaRS1800
Alright Sean,
aint seen you tearing around lately. hows things?
Yea im never going alcon again. Gonna switch back to a std flywheel just incase that was causeing probs and use a std frst clutch or maybe stg 1 organic for now and see how it goes. I havent got massive amounts of torque so i think it should be fine for awhile
Old Mar 13, 2006 | 04:22 PM
Neil@FastFord's Avatar
Neil@FastFord
good luck with it geezer!
see you soon
Old Mar 13, 2006 | 04:24 PM
Sunil_FiestaRS1800
see you soon
Yea cheers mate, with a bit of luck she will be running this weekend if i can get hold of a clutch
Old Mar 13, 2006 | 05:41 PM
SteveB's Avatar
SteveB
In 2 of my clutch books at work they list the Fiesta RS1800 as having a 240mm clutch as std and the XR2i 16v having a 220mm.....anyone shed any light on this as I've not had a gearbox out of a RS1800 b4????
Old Mar 14, 2006 | 08:09 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
if the RS1800 uses a 240mm clutch its running an MTX75 box, do you have lift reverse steve?
you should have if its a MTX box as all BC and IB5 boxes are bottom right reverse.
easiest way to tell
the xr2i will just be a std escort/fez box with a 220mm clutch
Old Mar 14, 2006 | 08:15 AM
Sunil_FiestaRS1800
if the RS1800 uses a 240mm clutch its running an MTX75 box, do you have lift reverse Steve?
easiest way to tell
hows it possible for mtx75 to fit as i thought they were slightly longer and needed part or the metal in the wheel arch flared out towards the wheel?
Old Mar 14, 2006 | 08:21 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i dont know on the fez mate, but on S2 turbos you hve to cut and plate a bit of the chassis rail. Jano has done this a few times.
i could well be wrong witht he 240mm clutch in a fez being on a MTX box, but im pretty sure that the mondeo/240mm flywheel wont fit in a IB5 box.
Old Mar 14, 2006 | 05:11 PM
Badman38's Avatar
Badman38
Alright Sean,
hi m8
i hardly drive the frst 750cc injectors even with closed loop lamba its not the most economical plus i've still got a few issues to sort out, like my steering ,brakes,clutch,alarm,roll cage ready for the fiesta thrash, are you convoying up to bruntes?
Old Mar 15, 2006 | 08:33 AM
Sunil_FiestaRS1800
Alright Sean,
hi m8
Hadnt organised to convoy up with anyone yet. Up for it though
yatta
May 21, 2016 10:31 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
