Why do people fit Diesel Gearbox's to RST's?
Old Mar 12, 2006 | 02:15 AM
Dan's Avatar
Dan
Default Why do people fit Diesel Gearbox's to RST's?
As above really, thinking of looking a Series 1 with a Mk6 1.8 diesel gearbox and paddle clutch, not happy with it at all but will it make THAT much of a difference?
Are they actually any stronger, or should I get the Series 1 'box to go with it?
Old Mar 12, 2006 | 08:05 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
They fit them for a couple of reasons;
The first main reason is that people believe they are stronger, which is bollocks in the mk3- mk4 gearbox, however the mk6 gearbox case is likely to be an IB5 casing, these are stronger as the bearings are bigger. If it is just a standard diesel box you won't have an LSD either
The other reason is of course ratios, diesel gearing is higher than an RST, especially in the S1 which had even lower gearing.
Can't think of anything else at the moment, I mean, have you seen the time, man? I'm still a bit hungover
Old Mar 12, 2006 | 10:36 AM
adamS2RST's Avatar
adamS2RST
Old Mar 12, 2006 | 12:14 PM
Ben26's Avatar
Ben26
Default Re: Why do people fit Diesel Gearbox's to RST's?
because they are TWATS
lack of an eduacation
BEN
Old Mar 12, 2006 | 04:24 PM
Dan's Avatar
Dan
Cheers Tony, appreciate the advice mate!
Do Series 1's have LSD's in their standard 'boxes then?
Old Mar 12, 2006 | 04:27 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Dan
All RST gearboxes have LSD's mate, what people do it take it out and bung it in their Fiesta boxes. As Tony says, the ONLY real advantage is a taller 5th gear.
Old Mar 12, 2006 | 04:36 PM
zippyobrien's Avatar
zippyobrien
dielse gear box has a shorter first gear aswell to make up for lack off power, meaning u will only hit 25-30 in first
Old Mar 12, 2006 | 05:44 PM
Dan's Avatar
Dan
Think i'll get the bloke to include the Series 1 box in the sale then!
Whats an average price for a Series 1 gearbox? and will the Paddle Clutch fit the Series 1 box?
Old Mar 12, 2006 | 09:05 PM
ldack's Avatar
ldack
Havent run my car yet but its a standard box and is meant to have diesel second and fifth gears. Will there be much of an advantage?!
Old Mar 12, 2006 | 11:01 PM
Mr S1's Avatar
Mr S1
Decent box has got to be £250......depends what size the paddle is. You can run either a 200mm clutch which is standard S1 size or 220mm which is S2. As long as you've got the corresponding size flywheel you can use either but 220mm would be better.
Old Mar 12, 2006 | 11:15 PM
XR2's Avatar
XR2
Diesel boxes would be good on german motorways... you could drive 260 km/h or a little bit more. But they're not much fun if you're not on motorways...
Old Mar 13, 2006 | 01:13 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Could fit a better gearbox all together than a 20 year old box of nails
MTX75 has the BEST gear ratios for all of the engines i have seen like CVH Zetec etc.. Even a YB FWD
+ How much is a decent MTX75 gearbox? Ask your local breakers or search Ebay... i have seen them from £30 upwards. A std box will take 330bhp no probs..
Anyways enough said...
Old Mar 13, 2006 | 09:23 AM
XR2's Avatar
XR2
There's simply no BEST gearbox for a car/engine. Depends on what the driver wants. I like a short one like S1 ERST but when I drive on motorways I'd prefer a longer one like S2 ERST. And with a 330 bhp engine MTX also would be too short for me And the few hp more a MTX can take it isn't worth changing it As far as it can be fitted
Old Mar 13, 2006 | 09:42 AM
Versus_Creations
Ask me a question!
There is no way an MTX75 will be too short for you
Its THE only box that can supply a genuine 60+mph in 2nd gear.. Dont belive me, go and try with your own box
An MTX75 will take you accross the 1/4mile line in third gear at 100mph+
Go figure
Old Mar 13, 2006 | 09:50 AM
Tony Turbo's Avatar
Tony Turbo
That all depends on what you rev your engine to...
Old Mar 13, 2006 | 10:22 AM
Dan's Avatar
Dan
So whats a good price for a Series 1 box?
Old Mar 13, 2006 | 01:31 PM
Mr S1's Avatar
Mr S1
A decent one is £250.............rare now. Which is why I've got a brand new box sitting in my garage for a S1
Old Mar 13, 2006 | 03:21 PM
Dan's Avatar
Dan
Wanna sell it?
Old Mar 13, 2006 | 03:23 PM
Mr S1's Avatar
Mr S1
Wanna sell it?
No besides you couldn't afford what I'd want for it.............
Old Mar 13, 2006 | 06:56 PM
Dan's Avatar
Dan
Think I'll have to get a car first!
Old Mar 13, 2006 | 06:59 PM
Mr S1's Avatar
Mr S1
That would be a good start
Old Mar 13, 2006 | 08:13 PM
Dan's Avatar
Dan
We'll see soon enough
Old Mar 13, 2006 | 08:17 PM
Mr S1's Avatar
Mr S1
If you buy a S1 - buy something decenht, not a shitter.............
Old Mar 13, 2006 | 08:29 PM
Dan's Avatar
Dan
Will do mate, I know of one that's got a pretty good spec on it and has been cared for somewhat, but also got a couple of Series 2's to look at with decent specs
Billy_RS
16
Oct 11, 2025 09:41 PM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
