S2 RESTO HELP
Old Mar 11, 2006 | 05:23 PM
Adam1's Avatar
Adam1
Default S2 RESTO HELP
Hi, i am restoring my s2, i have stripped the car down to a shell, there is nothing else to take off, no glass, no suspension, no brake lines, no doors, boot or bonnet, nothing, i now want to get the under seal off from underneath, i have the tools but dont fancy laying on my back, under the car with the grinder in my hand, i wanted to now if anyone could suggest how to put my car on its side, it doesnt weigh much but i dont want to just go and tip it over and bend something because of the weight and the way the car is lying, how should i support it, etc, if anyone has done this before please let me know how you did it as i seem to learn by mistakes an i dont want to learn "HOW NOT TO DAMAGE A S2 BY ADAM W", any help would be appreciated, cheeRS.
Old Mar 11, 2006 | 05:54 PM
Adam1's Avatar
Adam1
anyone
Old Mar 11, 2006 | 06:05 PM
Adam1's Avatar
Adam1
Old Mar 11, 2006 | 06:07 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
No point getting angry mate. I don't know anybody that has turned their car over. Chill out and have a beer
Old Mar 11, 2006 | 06:09 PM
Micky's Avatar
Micky
Easy one this.Put 10 old tyres on the ground and roll the shell onto its side.Easy mate Regards Micky
Old Mar 11, 2006 | 06:18 PM
Adam1's Avatar
Adam1
Not getting angry lad's and lasse's, i just dont want to damage my car, it's being painted so surface scratches wont be a problem, i will give it ago tommorrow folks, thanks for your help,
Old Mar 11, 2006 | 06:21 PM
S1's Avatar
S1
You need to make yourself a rollover jig.
To strip off the underseal, you need to use a combination of wire bush drill attachments, strip discs, etc. Its a long process! After the underseal is stripped I would suggest you get the shell sandblasted underneath toremove all traces of corrosion/surface rust and then give a good coat of etch primer.
Old Mar 11, 2006 | 06:22 PM
Micky's Avatar
Micky
Just found this picture,taken just before we rolled it onto its side,you can see a tyre ,but there are a good few more out of shot.Regards Micky
Old Mar 11, 2006 | 06:23 PM
Damo V's Avatar
Damo V
As above the only sure way of not damaging it would be a rollover Jig, commonly refered to as a "Spit"....
Old Mar 11, 2006 | 06:38 PM
Adam1's Avatar
Adam1
Nice one, i will give it ago, i did think originally about using two mattress's, 1 underneath the car's side and 1 on the roof against the wall, but i dont really want to buy 2 new or second hand ones, it's to much hassle, i suppose i could have a roam around in the car tonight im sure i would be able to find 2 p**s and s**t stained mattresse's in and around the country lane's, no seriously i will try the tyre thing tommorrow, money is a bit tight so i will have to leave the jig (spit), unless i can make one, ,thanks again, adam.
boeb
Jan 9, 2020 05:11 AM
Rod-Tarry
237
Mar 18, 2016 09:13 PM
IanC
Sep 5, 2015 09:38 PM
cossie_chris
39
Aug 31, 2015 11:58 AM
155lee
14
Aug 22, 2015 12:15 PM
