spring recomendation on a cossie please
Old Mar 10, 2006 | 11:52 PM
RSCossieGaz's Avatar
RSCossieGaz
Default spring recomendation on a cossie please
Whats best springs to run on a sapphire cosworth with 25mm drop with lets say std shocks?
Old Mar 10, 2006 | 11:53 PM
SPADGE's Avatar
SPADGE
Curly metal ones Gaz
Old Mar 11, 2006 | 12:01 AM
RSCossieGaz
joker
any particular make ppl recomend as im fed up with the spax adjustables/chassis dynamics on there at the mo rides pretty shite
want to regain a more comfortable ride anyone got any surgestions
Old Mar 11, 2006 | 12:06 AM
bassboy's Avatar
bassboy
my cousin ran Koni shocks with chassis dynamics springs and the ride was excellent...
if you pop down to work tomo ill see if i can price some up for ya
also any luck with the Cobolt gauges?
bassboy
Old Mar 11, 2006 | 12:37 AM
Jim Green's Avatar
Jim Green
Give Mike "R" a call, he got me some Ahmed Springs for my Sapphire Cossie, 25mm Drop, good enough for track days, and also nice as an every day driver.
Very Pleased with them and they're on Koni Adjustable shocks
Old Mar 11, 2006 | 06:12 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
bassboy
This is what i run and i find it to be a good ride
Steve.
Old Mar 11, 2006 | 06:20 AM
RSCossieGaz
getting the feeling konis may be the way to go alot of ppl rating them if thats the case just need to diside on what springs.
end of day car aint gonna spend its time on track so just want a good comfortable ride.
Old Mar 11, 2006 | 10:33 AM
Jim Green's Avatar
Jim Green
Yep, as a road and occasional track day, Koni's are a good choice. Definately Give Mike Rainbird a call about the Ahmed Springs, I think they're just what your looking for. 25mm Drop (Sensible), and subtle enough for the road.
I've been in a couple of Sapphire Cossies who have also had Koni Dampers, but different springs, and they crash their way over any bumb in the road and feel horrible compared to mine which uses the same shocks (Koni) but with the Ahmed Springs. They're also a linear spring, so the same spring rate regardless of compression (Within Reason of course).
Old Mar 12, 2006 | 08:46 AM
charlie luciano's Avatar
charlie luciano
Default suspension set up
i run with avo coil overs, their good cos you set them how you want,slammed or reasonable, handy if you want to run with 18"rims, wheel arch may need a roll in this case, i think they are a bit hard though,
c l
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
