have just fitted a second hand turbo unit and it is only boostin 2 psi, i changed over my actuator but didnt adjust the rod or anything, , , any ideas ???
is it the same actuator as u had? If the bracket is in a slighlty different position, it will alter the boost, it only needs to have moved a tiny amount.
adjusted the actuator rod this afternoon until car was boostin near enough same as before, will take it to my local tuner to make sure it is setup correctly..
