escort cossie rims on s2
help
can any1 tell me what arch-work i need 2 do to get my escort cossie rims 2 fit on my s2 escort rst?. what suspension would be best 2 use?, and how low should i drop it once the wheels are on?, the rims are wrapped in 215/45/16 tyres at the moment will these be ok? or would 205/16s be better, any advice would be much apreiciated. cheeRS
Stop shouting and take the Bold off mate!!
Try sending Thrush (Matt) a PM as I think he had proper EsCos wheels on his MK3 XR3i.
You'll need to do a fair bit of arch work I imagine, i.e Cut and roll the lip and probably remove the inner plastic arch liner.
As far as tyres go I think because there 8 inches wide the thinnest tyre you can get on there is a 215, and you'll need at least a 40 profile less if you can get it made!!
Hope this helps
Hope this helps
they look cool and i know they will fit if set up right and with a bit of arch work but what im concerened about is how it will affect the steering as the are what 25mm offset????!!!??
i think i'd go for 205/40's on mine just to keep a bit of side wall but allow car to be lowered some.
still interested to find if its possible to machine the offset to a greater one??
opinions????????
opinions????????
Billy_RS
16
Oct 11, 2025 09:41 PM
