No Power to the ECU--Help
Old Jul 27, 2004 | 05:42 PM
TIFF's Avatar
TIFF
Chasing Radders
Default No Power to the ECU--Help
Right, the car wont start but it will turn over.
No dashboard lights, indicators, windows etc etc
Spoke to Matt on the phone and he said check the power to the ECU
I have no power to the ECU
Was driving along fine, flashed the headlights and now nothing
Where do i look, all the fuses under the bonnet are fine?
Old Jul 27, 2004 | 05:43 PM
cossie1's Avatar
cossie1
check the main relay under the glove box as said last night m8
Old Jul 27, 2004 | 05:45 PM
TIFF's Avatar
TIFF
Chasing Radders
I swapped all the relays in turn for one i know works and still nothing???
Is there anyway to check a relay???
Old Jul 27, 2004 | 05:46 PM
cossie1's Avatar
cossie1
not that i know of
ok unplug the main relay, and find the 2 thickest wires on the plug (the bit on your other hand, lol)
now bridge them out (so no relay is used) and see if that makes any difference
Old Jul 27, 2004 | 05:47 PM
cossie1's Avatar
cossie1
oh
repaeat same again on the fuel pump relay aswell
TIFF's Avatar
TIFF
Chasing Radders
How do i know which is the main relay (Im shit with electrics )
Old Jul 27, 2004 | 05:48 PM
cossie1's Avatar
cossie1
there are 2 yellow ones, main relay has no fuse on the same feed, the fuel pump has a fuse next to it..
also if that don't work
check the phase and crank sensors
Old Jul 27, 2004 | 06:01 PM
TIFF's Avatar
TIFF
Chasing Radders
These relays are connected to the loom i take it
cossie1's Avatar
cossie1
YUP
Old Jul 27, 2004 | 06:02 PM
RANJ's Avatar
RANJ
check your grounds
Old Jul 27, 2004 | 06:40 PM
Damo V's Avatar
Damo V
This happened on my car I know it is VERY different to a degree, was driving along flashed headlights to let someone across, I lost all cabin electrics, radio dash lights, also found all exterior lihts were shot no indicators either or brake lights... car still drove though... turned out to be my fusebox, which is obviously a common problem on escorts, and easily removed to inspect, dunno about yours though Im afraid
Old Jul 27, 2004 | 07:15 PM
DazC's Avatar
DazC
Tiff,
If you have no ignition lights I.E no ignition feed then your ECU will have no power.....you need to find why there is not ignition feed to anything....
Old Jul 27, 2004 | 07:33 PM
markk's Avatar
markk
TIFF-C20WTH,
if you aint got all of them then the problem is way before the ignition relay m8 , all the ignition relay is for is the power side of the engine , not for the wipers and indicators etc etc , you need to look at main supply to the fuse box and or ignition switch , even though the car turns over , this may suggest that the 3rd sector of the ign switch works and also the power in from the battery but says nothing about accesory (pos 1 ) and ign on (pos 2) time to get the test light out and remove a few covers and cowls !!
good luck !!
if i were a bit close id have a look for ya !!
Old Jul 27, 2004 | 07:41 PM
lancia delta 6 times WRC's Avatar
If your crap with electrics and are not confident with what your doing get an auto electrician to look at it.
The price he would charge is minimal compared to the damage you can do linking things out at random.
stu (systems technician P+C)
Old Jul 27, 2004 | 09:07 PM
Neil S's Avatar
Neil S
Good advice there Stu.
Did you consider it may be an immobiliser on the blink?
Neil.
Old Jul 27, 2004 | 09:30 PM
DazC's Avatar
DazC
Tiff?
Old Jul 27, 2004 | 09:35 PM
RSCAT's Avatar
RSCAT
i had similar thing few weeks back, flashed the lights and the whole thing cut out, turned out to be one of the wires goin to the pos on the battery, stripped it down, new connecter and good as new. well it was the engine blew up
Old Jul 27, 2004 | 09:40 PM
TIFF's Avatar
TIFF
Chasing Radders
markk
Thanks for the offer mate
All sorted now thanks to Shings
He came over and we tested most of the things that need testing.
Took the steering cowl off and he had a good route about and spotted a Pink wire had broke off a Fuse connector Reconnected and taped it up and now she is running fine
Left it running and gave everywhere a good shake of the loom etc and all was fine
So BIG BIG thanks to Jake for helping me out Cheers Buddy
Old Jul 27, 2004 | 10:10 PM
DazC's Avatar
DazC
Sounds like someone has been playing around with your loom.....
Old Jul 27, 2004 | 10:12 PM
SPADGE's Avatar
SPADGE
Pink wire???
That'll be the one for your vanity mirror in your sun visor you big poof :gayflag:
Old Jul 27, 2004 | 10:13 PM
Matt's Avatar
Matt
now go remove the tape, split the wire again, and solder it you bodging bast !!!
Old Jul 27, 2004 | 10:14 PM
Shings's Avatar
Shings
some fucking sparrows if u ask me
TIFF's Avatar
TIFF
Chasing Radders
#Spadge pops outside and makes sure he doesnt have a pink wire aswell#
Old Jul 27, 2004 | 10:15 PM
Shings's Avatar
Shings
Matt- its allright theres a fuse holder and the wire had removed its self from the end of this. Recrimped and back on. Tape just for 100% good mesure to stop it going anywhere again.
J
Old Jul 27, 2004 | 10:17 PM
Matt's Avatar
Matt
okydoky then mr techy
Old Jul 27, 2004 | 10:18 PM
DazC's Avatar
DazC
Still a fooking bodge!
Old Jul 27, 2004 | 10:20 PM
SPADGE's Avatar
SPADGE
J
I wonder what thats for then? No pink wires under my dash that i recall Must be something to do with an immob or something!
Old Jul 27, 2004 | 10:21 PM
Shings's Avatar
Shings
Daz I'll bodge my wire cutters in ya eye if you suggest I am a shody bodge merchant again!
(just because I attached my last radiator to the front of my car with cable ties)
J
Old Jul 27, 2004 | 10:22 PM
Shings's Avatar
Shings
If it was then Tiff has a GAY imobiliser
Old Jul 27, 2004 | 10:23 PM
TIFF's Avatar
TIFF
Chasing Radders
Spadge
Really dont know what it was for but it now runs again
Old Jul 27, 2004 | 10:24 PM
SPADGE's Avatar
SPADGE
Originally Posted by TIFF-C20WTH
Spadge
Cool mate and well done Jake
I didn't need to look btw as i know every single wire in my fookin car
DazC's Avatar
DazC
LOL! Bodge!
Prehaps it was the feed for the ignition Tiff?
Old Jul 27, 2004 | 10:25 PM
Matt's Avatar
Matt
and tiff rang you for help i reckon he needs more help than just with his car then ROFLOL
Old Jul 27, 2004 | 10:32 PM
TIFF's Avatar
TIFF
Chasing Radders
What help was you then big boy
"If you have no power to the ECU then i having got a fucking clue as i have a Dingy loom"
Old Jul 27, 2004 | 10:34 PM
TIFF's Avatar
TIFF
Chasing Radders
Spadge
The funny thing is though you are not joking mate
Old Jul 27, 2004 | 10:37 PM
3drstretch's Avatar
3drstretch
[quote="TIFF-C20WTH
"If you have no power to the ECU then i having got a fucking clue as i have a Dingy loom" [/quote]
Then GET one then.You know you wanna.
Old Jul 28, 2004 | 07:19 AM
Matt's Avatar
Matt
read as
"if you have no voltage reading from pin 1 and 20 then you need someone who hasnt got a modified loom cos i cant compare mine"
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
