Techie Q emissions...Stu?
Old Jul 27, 2004 | 03:50 PM
plynchy's Avatar
plynchy
Default Techie Q emissions...Stu?
Just had the saff MOT'd. Bloke doesn't normally bother checking the CO,but i got it checked anyway out of curiosity. Running a stg.1 Bayjoo chip,Pipercross and 'goose exhaust. This is what i got:
Idle 1.6
2000 rpm 2.8 ish
3000 rpm 6.2 ish
Now is it so high at 3000 cos it should be starting to boost (but isn't cos it's in neutral) or am i burning a lot of Optimax for nothing??
Advice please!
(cunningly edited to attract attention)
Old Jul 27, 2004 | 04:12 PM
Jim Galbally's Avatar
Jim Galbally
its not done RPM related... the MAP input is used to work out boost...
ie the car should fuel perfect at 1psi all thru rev range and also fuel perfect at 30psi all thru rev range with no alterations
altho im sure i just explain thats REALLY badly
Old Jul 27, 2004 | 07:13 PM
plynchy's Avatar
plynchy
Anyone?
Old Jul 27, 2004 | 07:16 PM
bigal1978's Avatar
bigal1978
i tho the more revs the more fule?
Old Jul 27, 2004 | 07:22 PM
plynchy's Avatar
plynchy
So did i,but should that increase the CO that much?
Old Jul 27, 2004 | 09:24 PM
Karl's Avatar
Karl
Norris Motorsport
No, as std, (same basic fuel map as a stage 1) a cossie will run at around 0.5%CO at the rpms you mentioned when revved in neutral.
I run my own stage 1's at around 2% CO cruise but thats personal choice.
6% is a tad rich and wont be helping your fuel economy when driving at very light throttle.
Old Jul 27, 2004 | 09:37 PM
RSrussell's Avatar
RSrussell
fpmsl, good map
Old Jul 27, 2004 | 09:41 PM
Ima-Racing500's Avatar
Ima-Racing500
Karl he asked for Stu If he wanted someone who calls ME IMA Racing a sick twisted person..it would have said "FAO that goon that called IMA Racing a sicko"
Old Jul 27, 2004 | 09:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sounds more like excessive fuel pressure than a bad map to me initially.....
Old Jul 27, 2004 | 09:50 PM
Spiky's Avatar
Spiky
so at 3000 what i expect to see on mine??????
in neutral
Old Jul 27, 2004 | 10:01 PM
3drstretch's Avatar
3drstretch
A BIG cloud of Black Smoke.
Old Jul 27, 2004 | 10:03 PM
Spiky's Avatar
Spiky
thats sooooooooooooooooooooooooo true
Old Jul 27, 2004 | 10:15 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mines got a fair bit of black smoke at idle, i de catted it last night and fitted a ST170 4-2-1, is that why???
or is my power boost valve set too high????
Old Jul 28, 2004 | 06:50 PM
plynchy's Avatar
plynchy
Thanks fellas. So,i am just wasting fuel or am i going to create long term problems(bore wash etc)?
If the fuel pressure IS too high does that mean my regulator is poorly or something else?
It's running yellows( )by the way! Have got no problems with the performance tho.
Any further advice appreciated
BigErn
Mar 10, 2008 08:15 AM
Red16
58
Jul 31, 2007 02:07 PM
SapphyMike
Jun 14, 2007 09:08 AM
cabrio zo
12
Mar 21, 2007 03:52 PM
Cola
122
Jul 27, 2005 04:25 PM
