whats needed for rear disc conv. on my S2 ERST?
Old Jul 27, 2004 | 02:32 PM
Cawood's Avatar
Cawood
Default whats needed for rear disc conv. on my S2 ERST?
hey all
exactly what bits do I need to do a rear disc conv. on my ERST.
and what do you reckon its gonna cost me?
cheeRS
dave
Old Jul 27, 2004 | 04:01 PM
Lee Reynolds's Avatar
Lee Reynolds
£250 for kit from zoo motorsport using 2nd hand calipers
Old Jul 28, 2004 | 09:13 AM
Cawood's Avatar
Cawood
Cheers Lee
was hoping for list of items I would need so I can try get hold of them a bit cheaper, do it on a budget like
is it 2wd rear calipers and discs?
RS2000 handbrake cable?
adaptor plate (think mad for it do em)?
is that the lot I need?
also need the ST170 front setup as my cossie one is shite!
cheeRS
dave
Old Jul 28, 2004 | 09:53 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Pads
And MOST importantly, a bias valve.
Old Jul 28, 2004 | 10:08 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I disagree there. I think it is a best to not use a bias valve. There is nothing quite like it when you get that warm feeling in your pants when you brake hard at 120+ mph pushing some turbo'ed Honda thing along the motorway and the car lunges towards the crash barrier.
Isn't that right Damo?
Old Jul 28, 2004 | 10:14 AM
Jim Galbally's Avatar
Jim Galbally
2wd calipers are the same as normal sierra calipers (those with rear discs that is) so muchos cheaper to nick em off a 1.6GL or something in the scrappy
altho saying that, new calipers aint all that expensive anyhow
Old Jul 28, 2004 | 10:22 AM
Cawood's Avatar
Cawood
cheers mike n jim,
any recommendations where to pick up some serria rear caliper's cheap?
found full kit for £150, with new discs n pads, recon'd calipers.
reckon i'm best just going for that?
cheeRS
dave
Old Jul 28, 2004 | 11:06 AM
paul cox's Avatar
paul cox
dont forget the little spacers & bolts,etc
and changing some bits and bobs over
and dont forget - lots of this
bias valve - i aint got one on mine,seams to work fine for me - and the mot brake testing machine proved its all nice and balanced
Old Jul 28, 2004 | 02:07 PM
Cawood's Avatar
Cawood
cheers paul, any ideas on what size spacers & bolt's i'll need and which bits and bobs need swapping over?
Old Jul 28, 2004 | 03:34 PM
Paul's Avatar
Paul
But if u have front brakes that are larger ie 325mm front and 278mm at back would u still need a bias valve?
Old Jul 28, 2004 | 04:27 PM
Damo V's Avatar
Damo V
Yes you need a bias valve if its the same brake setup as Tony........
Picture the sceneIm driving Tony's car M11... 120 - 130mph, right behind a Honda civic / accord IIRC..... for no reason whatsoever, he decides to brake???!!!! My reaction was to do the same obviously, at which point the N/S rear wheel decided it actually wanted to be an O/S front wheel!!!! The back end Properly tried coming round, which wasnt a funny experience at the time in an unfamiliar car!!!!!!! PROPER brown trouser moment !!
Old Jul 28, 2004 | 05:32 PM
Tony Turbo's Avatar
Tony Turbo
Old Jul 28, 2004 | 05:33 PM
richm's Avatar
richm
Pads
or the right sized discs to suit the application
273mm cossie discs are too big for the size/weight of an escort - mainstream sierra discs at 20mm less diameter (and cheaper ) are fine. Obviously different brackets are needed to position the calipers 10mm closer to the hub centre to suit the smaller disc
I can't grasp the sense in oversizing the brakes then doing extra work to limit the amount of braking effort available to compensate??
Old Jul 28, 2004 | 05:34 PM
Lee Reynolds
So lets hear how the bias valve works...then we all know why we need one
Anyone?
Old Jul 28, 2004 | 05:40 PM
richm's Avatar
richm
Anyone?
limits the hydraulic brake line pressure to the back brakes (and hence the amount of braking effort), that we've just spent good money upgrading
Old Jul 28, 2004 | 06:11 PM
paul cox's Avatar
paul cox
i have standard calipers on the from,the 300mm drilled disc's,running EBC green pads - with 2wd calipers on the rear,275mm drilled disc's,running normal EBC pads - this is with braided hoses and dot 5 brake fluid.
I have found me braking spot on - even on the brake tester ,at an mot place - they we all set up with the correct bias.
I DONT NOT have any sort of bias valve.
The spacer's were something i made up,as the ones you get,dont quite fit right - cant remember the size's
Old Jul 28, 2004 | 07:10 PM
SteveB's Avatar
SteveB
Originally Posted by Cawood
Cheers Lee
dave
The 4x4 cossie caliper and the ST170 caliper is the same its only the carrier that is different to house the 300mm disc
Old Jul 29, 2004 | 01:32 PM
Cawood's Avatar
Cawood
cheers again everyone,
ah didn't know that steve, I was going to swap as my brakes for the ST ones as my cossie ones are shite,but I dont know why?? (i realised this after picking my RS2000 up and the brakes on that are quality compared to the RST)
so if im using 4x4 caliper and 278mm discs up front, what rear set up should I go for?
also which discs are 283mm what I could use? are they cossie 2wd fronts?
cheers
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
Graceland
Jul 31, 2015 10:34 AM
