Mods to my RS1800
Old Mar 8, 2006 | 09:50 AM
JsTurbo's Avatar
JsTurbo
Default Mods to my RS1800
Its standard part from a air filter, and scorpion back box.
What decent mods can I do to reach around the 160-170 bhp mark.
Also where can I get cars mats from which have the RS logo on them. Cant find them anywhere, but seen them around on other cars.
Thanks,
James
Old Mar 8, 2006 | 10:19 AM
Phil_rs1800's Avatar
Phil_rs1800
To see that kind of bhp, you are going to need throttle bodies. You could use motorbike throttle bodies like of a gsxr1000 to keep the cost down, but you will need to use a focus st170 inlet manifold and you will also need an aftermarket ecu. You could then add a performance manifold and decat. This should see around 170bhp. The next step would then be headwork and cams etc.
http://www.fiestaturbo.com/forums/vi...er=asc&start=0
The main restriction with the zetec engine is the standard inlet, so to get any decent power you have to dump that.
Im going down the lines of a focus 2ltr inlet manifold (which flows better) and the 65mm larger central throttle body, then raceline cams and headwork. Not sure what power that will be producing but hopefully i wont lose as much torque as when you add throttle bodies.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
Brian
Sep 11, 2015 08:06 AM
