4X4 MANIFOLD / 2WD MANIFOLD, WHATS THE DIFFERENCE IN POWER
Old Mar 5, 2006 | 07:35 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Default 4X4 MANIFOLD / 2WD MANIFOLD, WHATS THE DIFFERENCE IN POWER
I`ve just fitted a 4x4 manifold and matched t34 turbo, i was gony just turn the exhaust housing to suit my 2wd manifold but decided to change the whole lot ( to lazy ) I no peeps say the 2wd is better but how much really am i going to loose
any help apreciated
Old Mar 5, 2006 | 07:40 PM
SPADGE's Avatar
SPADGE
2wd manifolds are only better if your going for 450hp+
Up to that level of tune the 4x4's are better
Old Mar 5, 2006 | 07:44 PM
NUTTIN RILLA
As im not going for that power ( atm ) i should be fine then spadge?
The only other problem i noticed is my exhaust down pipe is alot lower and now hits the ground when i go over some speed bumps
anybody wana swap exhaust
Old Mar 5, 2006 | 07:52 PM
SPADGE's Avatar
SPADGE
Uusual problem with the exhaust mate and your best bet if you can't live with it is to get a bit cut out of the downpipe.
Other than that it will be fine
jason_nike
Aug 18, 2019 10:53 AM
frug
Aug 26, 2015 06:46 PM
IAN RS2k
Aug 18, 2015 07:51 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Old ford
Jul 31, 2015 06:50 AM
