Best place for a turbo damper?
..i need a bailey type damper...the one that has 3 bolts to the rocker cover thing!Where is the CHEAPEST place for one..any make!!!
Plus the cheapest T4 turbo to airbox hose!!!
The dampers are on ebay for around a ton
Spadge i am using a cone...
You have PM!.
You have PM!.Also got a T4 trumpet to suite if you need one
PM'd you back
phil, the bailey type damper isn't all that great tbh, i have one and it looks good but doesn't quite do the job it's supposed to
(managed to snap the bracket on the turbo with mine)
needs more bracing to prevent movement of the turbo towards the head IMO, RS500 would probably be the best if you can fit one, and i know a seller on e-bay has them for around a ton
if not i'd have one fabricated by your tuner,whoever that may be now
or somebody good who can make you one up
oh and if you do decide on that type get the genuine bailey one,the rose joints are shite on the copies,they rattle about and vibrate until they are finally hot enough and have expanded to keep them still
bud-weis
Phil can't use an original rs500 item as he is using a 4x4 head which doesn't have the lip to bolt it to. He could obviously use a spec-r or similar bracket to remedy that but he is far too grippy to go to all that expence
Originally Posted by bud-weis
just noticed his 4x4 head on another thread. looks like bailey it is then
that's the problem, they look like they do a good job, and because they are shiny and have rose joints people buy them for well over £100, but all they do is hang the turbo, don't really offer any 'damping' and not much support
Phil,i'd be happy to send you mine temporarily so you can get a fabricator to make something similar (but better)
Matt Baxter
Sep 16, 2015 08:30 PM
Cameron
14
Aug 9, 2015 06:28 AM
