EEC IV Wiring diagram? PATS? circuits immobilised?
As topic any wiring diagrams about? ideally need pinouts on ECU ( for a N plate fiesta )
How does PATS work, does it cut fuel pump? what else?
Got an IGN live from fuse box into inertia switch (Black/red) Then, got a BROWN wire coming out of inertia switch, does it go into ECU or does it go direct to pump? only we are unsure if the PATS is up the creek or the aftermarket immob... There isnt continuity between inertia switch and pump
Thanks all
Thanks all
then a black red to pump.
Brown is the pumps earth.
Sorry looking at a schematics.
The pin 22 is the earth for the pump on this :s
Nah thats different to the PATS setup
Correct standard issue black/red into inertia, but brown out...
all 4 wires coming out sender/tank are brown
The car is running we dropped the tank to find which wire was the pump live, but still interested to know..
Pin 22 obviously goes to the earth side of the pump relay
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
