Idle setting on an XR3i????
Old Jul 26, 2004 | 10:06 PM
McPikie's Avatar
McPikie
Default Idle setting on an XR3i????
Which bit do I twist???? Its an MFi jobbie.
Also, shud it have an autochoke on it??
CheeRS
Old Jul 26, 2004 | 10:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Yes to autochoke..
Mixture crew is in metering head, idle screw is on TB.
Old Jul 26, 2004 | 10:08 PM
McPikie's Avatar
McPikie
Cheers stu.
If it stalls I have turned it the wrong way then, lol. Does the mix need setting as well if I alter the idle???
Old Jul 26, 2004 | 10:09 PM
yes.
Old Jul 26, 2004 | 10:11 PM
McPikie's Avatar
McPikie
damn, will take it the garage then. Oh, in fact, u busy for 10 mins on wednesday mate?? I can also pay my membership if I pop up
Old Jul 26, 2004 | 10:14 PM
I could probably spare you a measly 10mins if im around.. youd have to call em at work to see matey
Old Jul 26, 2004 | 10:15 PM
stevo's Avatar
stevo
in most cases turn the idle adjuster anti clockwise to increase idle. but not to much
Old Jul 26, 2004 | 10:17 PM
McPikie's Avatar
McPikie
OK stu.
2moz mite be a cleaning day, buying tax (me, tax, ) so weds is prob best.
I will call you. Oh, BTW, I make THEE best brew you will ever tast mate. Just let me lose in that kitchen for 5mins
"Lets rooooooock"
Old Jul 26, 2004 | 11:08 PM
Jim Galbally's Avatar
Jim Galbally
iirc you can also adjust the throttle stop screw aswell which is different to the idle bypass screw... this right?
if so do you perchance know the CORRECT clearance for the butterfly? somebody told me once and i completely forgot it was either 0.4mm 40thou, or 4thou (i know it had a 4 in it )
i assume XR3i and XR4i are the same clearance
ps whilst youre there, clean your throttle body with carb cleaner... when i did mine on my old XR3i it was SOOOOO gummed up that cleaning it raised the idle by almost 1000rpm!!!! those things get proper mingin!
RSmark84
Sep 13, 2015 01:29 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
3doorcozmess
Sep 7, 2015 01:32 PM
