how could i tell if i
Old Mar 4, 2006 | 06:59 PM
abdr500's Avatar
abdr500
Default how could i tell if i
how could I tell if I have a group a fuel pump on a escort cosworth .with out taking the tank apart is there a flow test I can do like see how much fuel comes out at a given time .if I took the fuel hose off the feed directly and trigger the pump to come on
Old Mar 4, 2006 | 08:06 PM
dave cos4x4's Avatar
dave cos4x4
not that haed to drop the tank and find out.
just try and have the least amount of fuel in as possible.
Old Mar 4, 2006 | 08:27 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: how could i tell if i
if it has an aeroqip hose from the tank it stands a chance it's uprated, if it's the original plastic hose it's probably standard
Old Mar 4, 2006 | 08:30 PM
dave cos4x4
mines areoquipped.
still got to check wats in it though as i have a new 023 or 003 to fit in it.
Old Mar 4, 2006 | 10:09 PM
abdr500's Avatar
abdr500
martin-reyland
it does have aerqip that must be good news then
Old Mar 5, 2006 | 08:59 AM
dave cos4x4
it tells that there may be a after market fitting kit on the pump.
Old Mar 5, 2006 | 12:41 PM
Damo V's Avatar
Damo V
for a rough idea run the car with the return from rail into a fuel can, time how long it takes for the can to fill up ...
Old Mar 5, 2006 | 08:10 PM
abdr500's Avatar
abdr500
Damo V
how long should it take and do i still have the regulator attached
Old Mar 6, 2006 | 08:34 PM
Damo V's Avatar
Damo V
yeah after the fuel reg at idle... cant remember flow rate , whatever it is 3.5 litres/min????????
Old Mar 6, 2006 | 08:39 PM
abdr500's Avatar
abdr500
Damo V
thanks will give that a go
