Can i put my gear box in first ???
Old Mar 4, 2006 | 12:00 PM
Ben26's Avatar
Ben26
Default Can i put my gear box in first ???
My engine is currently out of the car , i am goin to be puttin back in very very soon and just wondered if i can put the gear box in first then drop the block in.
Is there enough room to slide the block into the gearbox ????
I would make life alot easyer if i could cozz the fuckin gearbox support is a right shitter
Ben
Old Mar 4, 2006 | 12:26 PM
xr4x4rs's Avatar
xr4x4rs
yes
thats the way i do all mine
cradle first then gearbox
if you havnt fited your head on then fit the block first as its easier to do the engine mount bolt sup
then fit ya head
Old Mar 4, 2006 | 12:32 PM
Ben26's Avatar
Ben26
the engine is all back to gether , just a have the engine and gear box seperate.
Thanks for that, i think i will pop the box in first then, just need some gear box oil now then, what stuff is it again ???
Ben
Old Mar 4, 2006 | 01:19 PM
xr4x4rs's Avatar
xr4x4rs
tbh i carnt remember what gearbox oil i put in mine
also when fitting the engine make sure the bottom pulley is off as this will catch your inner wing and cus u grief
then once in just fit engine mount bit of a pain lining the bolt holes up but its easier that way
Old Mar 4, 2006 | 02:00 PM
Ben26's Avatar
Ben26
lovely jubbly
Ben
mk22door
49
Mar 26, 2022 07:15 AM
3i Jim
Nov 20, 2015 05:12 AM
Gadget
Aug 26, 2015 01:02 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
