whats this??? ecu question
Old Mar 3, 2006 | 07:19 PM
stu21t's Avatar
stu21t
Default whats this??? ecu question
i have a L1 ecu ( i think) and i opened it up to find this,
its a collins board,
what is it? is it just a replacement board needed to run a different chip?
or something else?
and the chip had the sticker sating 403s, 3bar and comp. but no number,
what comp housing would ytou normally run with greys and a 3bar? .63?
i would ring collins but they are shut and im inpatient. lol
Old Mar 3, 2006 | 07:30 PM
Billabong's Avatar
Billabong
It's Collins' copy of a Pectel protection board, basically. It doesn't necessarily mean it's running a Collins' chip though...best bet IS to ring them.
Unless I'm mistaken, the label is on the 'wrong' chip.
Old Mar 3, 2006 | 07:38 PM
stu21t's Avatar
stu21t
the label peeled off, it was on the chip to the right to start with but once i touched it it moved. lol
whats a pectel protection board??
cossies and pectel are all new to me
Old Mar 3, 2006 | 07:42 PM
Billabong's Avatar
Billabong
The Pectel (or similar) board was primarily introduced to protect a tuners work, by decrypting the software on the chip at run time - this was in an attempt to stop copying of chips..... they can also add useful features (depending on the board) such as anti-lag (for P8 EsCos ECU's) water injection etc.
Pectel is a company that made a mapping system for the Webber MArelli ECU's that our beloved Cossies use. The software creates an encrypted chip, the board decrypts it.
Stu did the 'perfect' description on a thread somewhere, which describes the ins and outs, but in a nutshell, what I've put above.
Not all tuners use them, some just use regular chips, and I think Stu @ MSD has his own protection system.
Old Mar 3, 2006 | 07:48 PM
stu21t's Avatar
stu21t
ah cheers m8
Old Mar 3, 2006 | 07:49 PM
SPADGE's Avatar
SPADGE
You sure thats an L1? What colour is the mixture screw?
Old Mar 3, 2006 | 07:55 PM
Billabong's Avatar
Billabong
Here you go (Stu's write up): https://passionford.com/forum/viewtopic.php?t=166532
Old Mar 3, 2006 | 07:56 PM
stu21t's Avatar
stu21t
no idea
i only say this as i was told its an L1.
how do you tell?
Old Mar 3, 2006 | 08:01 PM
Jay,'s Avatar
Jay,
Sponsor
that looks like a l6 to me
cheers jay
Old Mar 3, 2006 | 08:02 PM
Billabong's Avatar
Billabong
As SPadge said - on the left hand side (as per pic above) there should be a screw - the colour of this usually helps in identifying the ecu level.
There's L1 (3dr and RS500), L6 (2wd Sapph'), L8 (regular non cat' - early 4x4 Sapph' & cat with lambda - late 4x4 Sapph') and P8 (Large turbo EsCos)
stu21t's Avatar
stu21t
whats the difference between L1 and L6?
and what is this board if it is in a L6?
lol
Old Mar 3, 2006 | 08:04 PM
stu21t's Avatar
stu21t
well it came with a 2wd 205 block, dunno if its the origional ecu for that engine tho
cheers for the link but i cant read it. im not a gold member
Old Mar 3, 2006 | 08:05 PM
Jay,'s Avatar
Jay,
Sponsor
where the loom plugs in theres a screw what colour is it
Old Mar 3, 2006 | 08:08 PM
stu21t's Avatar
stu21t
the screw is white plastic,
theres a sticker on the lid of the ecu that says,
WD48.08/L3H.93
does this mean anything?
and what about the comp? would you say a .63 housing?
Old Mar 3, 2006 | 08:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
Thats a late manufactured Level 8 fitted with a Collins PE encryption board. Sticker on teh chip, is totally uselsss and meaningless to anyone. Best buy another chip to suit your spec is my advice.
Old Mar 3, 2006 | 08:12 PM
Jay,'s Avatar
Jay,
Sponsor
there u go pmsl
Old Mar 3, 2006 | 08:15 PM
stu21t's Avatar
stu21t
Originally Posted by Stu @ M Developments
Thats a late manufactured Level 8 fitted with a Collins PE encryption board. Sticker on the chip, is totally uselsss and meaningless to anyone. Best buy another chip to suit your spec is my advice.
and at the same time. lol
i guess l8 is good, y is the chip no good?
the engine came with a 3 bar and greys. and i have a T3/4 with a .63 comp housing.
this will only be a stop gap until i change the ecu for something else.
will i be able to fit a std chip to this to run std turbo, injectors and map sensor?
Old Mar 3, 2006 | 08:18 PM
Jay,'s Avatar
Jay,
Sponsor
did it all come off the same car was it all runing together if u dont no then its a good idea to get a new chip
Old Mar 3, 2006 | 08:20 PM
Billabong's Avatar
Billabong
Stu's saying that chips of an unknown source/spec (stickers aren't always reliable or informative enough) are best left alone to avoid damage to engine etc.
And basically, the later the level of ECU, the better.
To go back to a std chip, you'd need the std chip and std Ford daughter board (looks similar to the Collins board) The std Ford chip won't run in an encryption board.
stu21t's Avatar
stu21t
so i need a std chip and board to run the engine in then a new board and chip to run decent power. lol
L8 is teh best YB Ecu in my opinion. So thats good.
Chip is mapped for:
Injectors: 403s
Map sensor: 3bar
Fuel Pressure: ?
Compression Ratio: ?
Engine capacity: ?
Turbocharger: ?
Head ports: ?
Cams fitted: ?
Midrange spike: ?
Boost held: ?
Fuel Octane: ?
I wont go on....
Old Mar 3, 2006 | 08:23 PM
stu21t's Avatar
stu21t
lol @ stu
thats fair enough i get the point now. lol
how good would this ecu compare to say a new omex 750 or other new ecu out there that doesnt cost a fortune? like emerald/dta
Old Mar 3, 2006 | 08:26 PM
Jay,'s Avatar
Jay,
Sponsor
2 words live map
Old Mar 3, 2006 | 08:43 PM
Originally Posted by stu21t
lol @ stu
For a 400bhp ish engine? Very little in it to be honest, and in many cases L8 is better. Just get it mapped live, ideally with closed loop fuel control,and your away, 400+bhp and 30+mpg with total dependability and reliability.
Remember, even if you buy DTA or similar, you still have to pay someone to map it. You would likely be financially better off keeping your L8.
Old Mar 3, 2006 | 08:51 PM
stu21t's Avatar
stu21t
mmmm
defo something to think about
but i might want to run other bits in the future,
such as
nitrous, WI, launch control, full throttle gear change, anti-lag, boost control, possibly 8 injectors, coil packs...
all that sort of stuff, can the L8 handle this?
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
