cossie thrttle body diameter please??
Old Mar 2, 2006 | 07:46 PM
M K's Avatar
M K
Default cossie thrttle body diameter please??
as abve i need the outside diameter of the throttle body (part your hose goes onto)
mines down the ngine builders
thinks its about 63mm-70mm
just gotta check
cheers
Old Mar 3, 2006 | 05:46 AM
M K's Avatar
M K
for the morning crew
Old Mar 3, 2006 | 03:27 PM
M K's Avatar
M K
someone must know
Old Mar 3, 2006 | 03:33 PM
SPADGE's Avatar
SPADGE
A standard 2wd throttle body has an external diameter of 65mm mate
Old Mar 3, 2006 | 05:16 PM
M K's Avatar
M K
ok,,cheers mate,,
means ive ordered the wrong size hose i got 70mm in my head when i ordered for some reason,,,,should of double checked
Old Mar 3, 2006 | 07:02 PM
Paul.'s Avatar
Paul.
Sierra cosworth 2 & 4 WD is 63.5mm (2 1/2")
Escort cosworth T35 is 63.5mm
Escort cosworth T25 is 70mm
RS500 is 76mm.
Regards Paul.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
