Ride height and its effects
Ok i found that my GTR is 20mm higher at the back than the front...so is making it level with the front the best set up for looks and handling?
I have no idea re handling as i had Spax on my Cossie and it so low i couldnt get over speed humps
Phil, unless you have a complaint with the handling, then ideally leave it alone.
If however you have chronic oversteer, then lowering the rear would tend to improve rear end grip (assuming that lowering didn't alter the geometry so as to give too much camber / toe etc).
Cheers mate...but it looks so much like Pon in a gay bar with its arse in the air
.....so i ideally want to level it out.
Any more views?As frankly just 1 reply is not good enuff...its like being treated like a newbie.....LOL.
Phil, after zoo corner weighted mine, it lowered the rear and the car is very flat now. I had the beam and other bits on at the same time so I cannot accurately desdcribe the effect of leveling/corner weighting the car on its own. What I will say is that it handles like a dream. Maybe leveling yours out will help. Do you have coilovers on the rear?
Deck it.
Unless you are continuously doing track days phil, you will realise that your greater needs would be for looks. I didn't know skylines did off roaders, and the only form of motorsport they used to excell at seemed to be JGTC and I tell you them ones looked awesome.
I doubt for one second that they ever nipped out to Tesco's for some dog food in them, but hey looks is IMO more important for you.
My car is v.v.low, even Mr. Gaybird comments on how my ride looks so good from the rear, but I do kill tyres due to an extreme camber, which also improves the handling!
Martin..i am really flattered by all the attension you give me,cool it mate or we might be seen as the next Rainbird and Pon ROFL
PS you are right...Skyline owners dont answer..wether its cause its me or cause they all enlist pros..in which case why the fook have a forum
Cheers CossyMad....i think your right..i dont drive more than 20mph anyway
Mike in YOUR dreams only
SMILER258
Sep 28, 2015 09:04 AM
