series1 leak?
Old Mar 1, 2006 | 11:30 AM
Paul17's Avatar
Paul17
Default series1 leak?
I've just discovered that the roof lining in my series1 is wet there must be a leak somewhere? the boot also gets very wet? i've change the boot seal and it's still leakin in somewhere. Any1 any ideas
Thanks
Old Mar 1, 2006 | 03:49 PM
jonnyturbo's Avatar
jonnyturbo
sunroof runners? common on s1s if they are gubbed the car will let in rain
Old Mar 1, 2006 | 03:53 PM
MikeyXR2i's Avatar
MikeyXR2i
Its possible the 2 rear sunroof pipes are leaking from where there connected into the sunroof pan, and all running back towards the boot.
Old Mar 1, 2006 | 04:10 PM
Paul17's Avatar
Paul17
jonnyturbo
What do ya mean by gubbed and how can i tell?
MikeyXR2i
how do i check if the sunroof pipes are fucked?? Please
Old Mar 1, 2006 | 04:17 PM
MikeyXR2i's Avatar
MikeyXR2i
You can either open the sunroof and pour water down the 2 rear holes in the pan to see if the inside of the car gets wet, i wouldn't do this myself.
Or at worst take headlining out to check em.
Old Mar 1, 2006 | 04:19 PM
Paul17's Avatar
Paul17
is the headlining not a nightmear to put back right?
Old Mar 1, 2006 | 04:22 PM
Micky's Avatar
Micky
Yes a total nightmare of a job Regards Micky
Old Mar 1, 2006 | 04:23 PM
MikeyXR2i's Avatar
MikeyXR2i
as above, yeah is in an S1, different in a FRST its as stiff as a board.
Paul17's Avatar
Paul17
is there not any other way of checking it???
Old Mar 1, 2006 | 04:24 PM
Paul17's Avatar
Paul17
how would you seal it or fix it?
Old Mar 1, 2006 | 05:05 PM
andre_k's Avatar
andre_k
for the boot, try the tail-light rubber gasket thingy
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
