s1 turbo on s2
just swapped my old series 2 turbo for a brand spankin new never been on a car s1 jobbie, connected the water pipes and run like a dream, well chuffed, no smoke anymore ( the oil seals had gone on the last 1) took it out for a spin and im gettin some luvely chatter
, never had it before (well not this loud) and runnin mfi! anyopne else done this conversion and found the same?
musn't be explaining meself very well. i connected the water pipes together thereby bypassing the turbo because there is no connections for the water pipes. i thought there was no difference apart from the water cooling but thought id ask cause im getting a lot of wastegate chatter
ahhhhh S1 turbo then
my t3 stage 3 isnt watercooled. and as said above doesnt mater what one ya use. unless your using it on a fiesta as i think if i remember its the S2 t3's aint good cause the water heats up of wear the turbo is seated??? maybe wrong
my MFI S2 chatters its arse off. it can also be a sign that your metering unit is fucked from what ive been told if its mfi....and mine was.
but if ya search chatter on here peeps explain it very well what it means/does. think it was in general discussion not so long ago
HTH
HTH
PMSL @ metering unit being shafted
it's the air rushing back through the turbine blades, thats all the noise is
called it fluttering, cos thats what it's doing (same as a bird, the noise is the air being moved arround)
you can self control the flutter too, dont take foot harshly off accelerator pedal, practise and do it softly or just in the right place and it lasts a little longer
but i do prefer the sound of that to a chud valve
I also remember someone a long time back explaining that if the metering head was fooked then that would also contribute to the effect of chatter.
Obviously it's the air stalling back through the turbo making the noise, but perhaps if the air-flap remains open (due to being fooked), that creates low pressure air that side of the turbo, then the higher pressure air from the other side wants to get to the low pressure side (due to normal air physics of low pressure/high pressure areas), so moves back through the turbo at a quicker velocity, causing a louder chatter noise than if the metering head was closed fully and the pressure on that side was slightly higher with a lower velocity movement result.
James: what difference does having a 0.48 housing have over standard ?
Previous owner of my car was told by Karl at NMS that the turbo had a 0.48 housing.
JK12
33
Apr 26, 2021 12:09 PM
