are HT supposed to not cross over each other?
are you suposed to keep HT leads away from each other? ie not have them overlapping etc?
if so, what problems can be caused by having em too close?
PassionFords Creator
Actually, it is technically bad to overlap and if you must do so, they should overlap at right angles.....
However.. whatever your problem is Jim, im sure its not caused by tghis little known phenomenon
i dont have a problem, i was just thinkin about it the other day when changing the dizzy cap n noticed its physically impossible to NOT have the leads overlapping on my car...
Originally Posted by Jim Galbally
i was dropped on my head as a baby
Meeeeeeeeeeooooooow
one for the road
Cos500
Sep 16, 2015 09:50 PM
