Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
mondeo service lights
Old Feb 28, 2006 | 09:41 PM
webby80's Avatar
webby80
Default mondeo service lights
does anyone know how to reset a 97 2.5 v6 mondeo service light????
Old Mar 2, 2006 | 08:12 PM
silencer's Avatar
silencer
phone a ford garage man quite sure they can piont you in the rite direction.
Old Mar 3, 2006 | 08:24 AM
nthorpey's Avatar
nthorpey
inside the glove box on some there is a small switch , I'm sure it actually tells you this in the manual but who reads those !
Old Mar 3, 2006 | 11:14 PM
angel 1's Avatar
angel 1
Remove the glovebox, there will be a switch on the left handside, push the button in then switch on the ignition, turn off and the light should go off.
Old Mar 11, 2006 | 04:08 PM
SiV6Si's Avatar
SiV6Si
Ign to AUX, remove glove box, switch on left ( picture of a spanner on it ) hold for 4 secs, turn of ign turn back on, Aux panel will light up ( self test ) then the lights will extinguish ( had 4 Ghia X's V6 amd 2.0 L ) HTH Si.
OR
in the bottom right hand side of the Aux Warning panel, should be a little hole, get a pin and stick it in ( this is the reset button for MK 2 mondeos )
Old Mar 12, 2006 | 02:38 PM
webby80's Avatar
webby80
Default brake light??????
thanks lads thats done the trick
anyone got any ideas on the brake warning light the car has js had new pads n disks but light js stays on
Old Mar 16, 2006 | 10:01 PM
SiV6Si's Avatar
SiV6Si
Check the hand brake switch as well as the front pad wear sensors as they both power that light.
Old Mar 16, 2006 | 10:16 PM
EssexBoyRacer's Avatar
EssexBoyRacer
This is on mk2 mondeos? I got a v6 ghia X V reg, never noticed any service or brake warning lights!?!
Are these on the "doors open" panel that the earlier models have? Mine is a late model with the climate control but just has a coin tray.
Old Mar 17, 2006 | 07:55 AM
angel 1's Avatar
angel 1
Hi! Essex boy racer jo here just letting you know that if you have a coin holder on the dash you wont have the picture of the car and warning lights, but would have thought you would have as you have got a mk2 ghia X as I have it and have got the mk1 ghia.
Old Mar 17, 2006 | 09:23 AM
EssexBoyRacer
I've noticed the later mk2s that have climate control rather than just air con don't have the warning lights in the coin tray. I'm yet to see one that does.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
turbowag
Sep 3, 2015 08:07 AM
