brake questions
Old Jul 26, 2004 | 01:42 PM
sm's Avatar
sm
Default brake questions
i need some 2wd cossie discs for my erst, what do u cossie owners recommend? prob gonna use mintex pads as they seem to work really well, also gonna remove the abs from my erst, does anyone on here do the brake lines with all the relevent fittings? i know u gotta use a different resivior but which one? and is it worth getting a bigger master cylinder?
any help appriciated
cheers kev
Old Jul 26, 2004 | 02:30 PM
Ryan's Avatar
Ryan
kev i got some standard 2wd cossy disc here if you want them mate, also got some drilled and grooved, but they will need machining as there slightly warped.
Ryan
PM me if you are interested.
Old Jul 26, 2004 | 02:37 PM
sm's Avatar
sm
cheers ryan but i really want some discs and pads by the same manufactuer if poss and grooved ones to stop the pads glazing over not keen on x drilled as my last set started to crack between the holes
matt there is a bigger master cylinder u can use, i just forgot what car to get one off doh!!! think i got a 3i res somewhere, ill be removing the abs myself just need to know if anyone on here does all the lines with the right connections
cheers guys
anyone else?
Prickly_buzz
Dec 7, 2017 09:52 PM
155lee
Oct 27, 2015 04:55 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
