3dr Cos suspension check out the rubbing on my arch,pics
Old Feb 28, 2006 | 08:27 PM
simonc's Avatar
simonc
Default 3dr Cos suspension check out the rubbing on my arch,pics
Used 235/40/17 on the rear of my 3dr at Brands yesterday, its made a bit of a mess of the shit catcher only did it when going through paddock hill.
Its got rear bilsteins & standard ride height 30 % uprated springs on the back & coilovers on the front, don't want to muck about with it too much now as it handles well like this. Going to put some heavier poundage springs on the rear , is this the answer ?
No damage to the tyre
Had a top day, anyone thinking of using Toyo R888 trackday tyres i found them really good, so much grip its untrue
Simon.
Old Feb 28, 2006 | 08:57 PM
warleydaddy's Avatar
warleydaddy
I want to run bigger rear tyres too,il runn 200 springs on the rear,and 400 on the front..Whats the MAX i can run tyre wise then??
Pete..
Old Feb 28, 2006 | 09:12 PM
K.Goa's Avatar
K.Goa
Warlydaddy, In my expirience those Toyotires are closer to slicks than roadtires grip-wise, you might want to uprate you springs..
Here is an example of how my car behaved on those tires with standard suspension:
Old Feb 28, 2006 | 09:16 PM
PDenbigh's Avatar
PDenbigh
Don't know much about the differences in the rear susp of a cossie and an Merkur XR4ti, but I run 245/45/16's on all four corners of my XR. I have front coilovers and 300# springs, and "sport" springs in the back that are -25mm below stock ride height... if that helps? I had to roll the fenders and do some minor "adjusting" to some of the inner fender well with a hammer, but it looks fine and once painted is unnoticable.
As for the scrubbing on the above pics, maybe use a spacer and roll the fenders?
Old Feb 28, 2006 | 09:51 PM
marco polo's Avatar
marco polo
HI mate
you might need to space the wheel out a couple of mm if it's rubbing on the inside
Marco
Old Feb 28, 2006 | 10:11 PM
simonc's Avatar
simonc
Wheel spacers seem a bit dodgy to me, does it not put more strain on the wheels bearings & you have less thread to bolt the wheels on. I have a pair of 5mm spacers from rally design, universal type ones but have never used them because i thought it would be a bit dangerours, keep thinking the wheel will fly off
Simon.
Old Feb 28, 2006 | 10:16 PM
Ryan's Avatar
Ryan
no different than getting bigger offset wheel
Old Feb 28, 2006 | 10:22 PM
simonc's Avatar
simonc
So if i have ET40 wheels & i use my 5mm spacers it then becomes ET35 ?
Does it matter that their will be 5mm less on the wheel studs to put the wheels bolts onto ?
Simon.
Old Feb 28, 2006 | 10:26 PM
Ryan's Avatar
Ryan
longer wheel studs may be needed, i.e 5mm longer than standard items.
HTH
Old Feb 28, 2006 | 10:27 PM
SPADGE's Avatar
SPADGE
Simon.
Personaly i wouldn't use the standard studs with a 5mm spacer mate
Gets some longer studs in there! GGR do them or try Steve at A1
Old Feb 28, 2006 | 10:29 PM
SPADGE's Avatar
SPADGE
Just another thought! If you use the spacers you may have to trim your arches as the problem may then occur on the outside!
Old Feb 28, 2006 | 10:34 PM
simonc's Avatar
simonc
OK thanks for the advise but it only rubbed on the inside when at the bottom of Paddock hill bend, i'm going to try stiffer springs 1st as i don't like the idea of spacers.
Thanks Simon.
Old Feb 28, 2006 | 10:39 PM
simonc's Avatar
simonc
Spadge, exactly what i was thinking, it will deffo hit the outer lip with a spacer on. I'll sort some springs & then see what happens next time i'm at brands. I don't think i would get this problem at other tracks as the dip you go down at brands is very steep & the suspension compresses to the max in the bottom of the dip.
Thanks Simon.
Old Mar 1, 2006 | 09:18 AM
maxest's Avatar
maxest
Are they 330mm Comp B4's???
..... If so what do you think of them? I've got some for my saph!
Old Mar 1, 2006 | 10:04 AM
lamb chops's Avatar
lamb chops
Take out the arch liners, job done Dont have any on mine.. Thought all 3doors were the same, looks like im wrong and now need to buy some, doh
Old Mar 1, 2006 | 07:08 PM
marco polo's Avatar
marco polo
Simon
make sure you get hub located spacers don't use universal spacers they are shit and your right your wheel will fall off because mine did on the motorway using universal one
i have got the hub located ones now i learn't my lesson
marco
Old Mar 1, 2006 | 10:14 PM
simonc's Avatar
simonc
Maxest yes they are a 330mm compbrake set up, quite pleased with them but i still had slight brake probs with the pedal going spongy sometimes, i had to pump the pedal sometimes after giving them a hammering. Not sure whether its fluid or brake pad related though, prob pads, i was staying out for 20 laps or so at a time though.
Marco, yes i have the universal ones & the quality looks crap , i will not be using them.
Simon.
Ben26
Ford KA
Sep 23, 2015 07:22 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
