Coilpack and electrical interference???
Old Feb 28, 2006 | 07:47 AM
CosRush's Avatar
CosRush
Default Coilpack and electrical interference???
What do i need to know with respect to mounting my coilpack and its proximity with other electrical components???
I realise it could cause some problems due to interference, but how close is too close........???
Any advice?
Old Feb 28, 2006 | 07:55 AM
Graceland's Avatar
Graceland
Team HOTHOT!
aslong as it is not mounted within 6 to 8 inch of the map sensor then you should be fine
Old Feb 28, 2006 | 07:59 AM
CosRush's Avatar
CosRush
So its only really the map sensor that needs to be worried about..???
Thats a shame as the space i have for it is about 5 inches below the map sensor
ok, will look at moving it elsewhere then...
Thanks
Old Feb 28, 2006 | 08:00 AM
Graceland's Avatar
Graceland
Team HOTHOT!
map sensor is the main one aye, 5" should be fine tho - you could make a bling little metal plate to go between them to dampen any interfearence
Old Feb 28, 2006 | 08:01 AM
kjc300's Avatar
kjc300
Surely the map sensor is smaller and easier to put somewhere else?? If you've found a good place for the coilpack!!
Old Feb 28, 2006 | 08:07 AM
CosRush's Avatar
CosRush
No not really........
I dont want to put the map sensor Turbo side because of the heat, obviously it has to be below the plenum for the pipework to be routed correctly, and the only place is a small panel about 6 inches wide by 12 inches high.
It already has my map sensor on it, and did have a conventional coil mounted near the bottom of the panel about 5 inches away.......
seems a shame now having removed the old coil to have the space and not fill it, especially when space is at such a premium
Old Feb 28, 2006 | 08:52 AM
Graceland's Avatar
Graceland
Team HOTHOT!
bang it in there and make a sheild plate - should be spot on then
Old Feb 28, 2006 | 08:56 AM
CosRush's Avatar
CosRush
Do you mean like a faraday cage???
or just a box....???
Old Feb 28, 2006 | 08:58 AM
Graceland's Avatar
Graceland
Team HOTHOT!
a sheild around the map sensor - nothing fancy, just a piece of stainless or something like that
Old Feb 28, 2006 | 09:00 AM
scruffythefirst's Avatar
scruffythefirst
If its any use my map sensor is at the bottom of the passenger footwell on a ali bracket and the coilpack is at the top on the battery shelf. At lease 10 inch apart and a fair bit metal between them.
Old Feb 28, 2006 | 09:03 AM
CosRush's Avatar
CosRush
Thanks fella's....
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
