power
Old Feb 28, 2006 | 06:31 AM
withamxr's Avatar
withamxr
Default power
i would like a bit more power from my s2 but i would rather not chip it. the car is running with a pace dc ic scorpion and KnN..is head work the way to go?
i dont want to spend mega money as it will be getting a big cappacity bottem end when it comes of the road after this summer show season
the car made 128 bhp and 164 ftlb with 112500 miles and would like 145 plus bhp
thanks
Old Feb 28, 2006 | 07:35 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Doing any headwork is pointless without raising the boost.
Also big capacity doesn't always mean big power.
Old Feb 28, 2006 | 08:55 AM
a11ova's Avatar
a11ova
you could use a cam but will struggle to 145bhp without more boost. problem u have then is that the ecu's boost limit is going to cut in if u try to turn it up.....hence theneed for a chip.
Old Feb 28, 2006 | 09:20 AM
ivorbiggun's Avatar
ivorbiggun
I.M.O......head work could well be the way to go/more power without having to increase stress's on engine internals with more boost is potentially a great way to go/if extra flow doesn't work without extra boost why do people with normally aspirated engines bother with head work? BUT get it done correctly
by someone who understands the above and flow dynamics. It won't be cheap but if done correctly it may well be a benefit to your next engine as well. See Dave at www.pumaracing.co.uk and you won't go far wrong.
HOWEVER....your Motor seems to be doing more than OK in the torque dept
for standard boost. Do you really want to enter the world of broken gearboxes,clutches,C.V joints,drive shafts, engine mountings etc? Or even look above at Tony's work of art, that's what happens when you get it really bad.
Old Feb 28, 2006 | 12:01 PM
JimmyBoy's Avatar
JimmyBoy
Surely he could raise boost from stock 7psi to the chips limit of 10psi ?
Old Feb 28, 2006 | 03:55 PM
addiction's Avatar
addiction
my old engine with a k&n,mongoose zorst,cvh 31 cam and pace d/c interwarmer was making 156bhp on 10 psi of boost
Old Feb 28, 2006 | 04:56 PM
andre_k's Avatar
andre_k
Default Re: power
at what boost? mine made 148bhp, 168lbft at 10psi after jamie@jamsport set her up
Old Feb 28, 2006 | 05:48 PM
withamxr's Avatar
withamxr
thanks for the advice
im running standard boost and mods as above (bar susspension/brakes)
power=128.0
torque=164.2@3865 rpm
fair for the milage i thought
Old Feb 28, 2006 | 05:51 PM
withamxr's Avatar
withamxr
set up by paul at engine advantages engine advantages
Old Feb 28, 2006 | 05:54 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Get a better IC unless its the newest front mount pace cooler, bin the K&N, bin the scorpion (unless it's also the newest model)
Mongoose, magnex/GRS/Pro alloy IC, standard/modified airbox with K&N panel filter.
and your already off to a better start IMO
Old Feb 28, 2006 | 06:02 PM
withamxr's Avatar
withamxr
trouble with the scorpion is it sounds great
restrictive as people say it is 10 years and 75k trouble free miles say it stays
cheers
Old Feb 28, 2006 | 09:00 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
u got to understand y u have posted in the first place (more power)
a restricted exhaust on a turbo car is not the way foward mate
i would rekon a cam etc or actuator will cost good bit money better of going for a chip then you can play about more,as you will still need a chip when u do bott end any way so no loss realy
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
