Opinions, Advice and thoughts....
Old Feb 27, 2006 | 10:03 PM
a11ova's Avatar
a11ova
Default Opinions, Advice and thoughts....
now that i have your attention im after some views and adviceon my project. Its early in the game i know but would like to know whats best and suggested in advance then i know which route to be taking and can make a start on my shopping list.
For those who dont know (will prob be most as im relatively new ) im building a 2.1 ZVH lump for my s2. Im looking for it to make a minimum of 300bhp @ the flywheel. I know in theory my idea should work but mainy of you on here will have the knowledge and experience to point me in the right direction (stu, chip, etc etc). Below is a list of parts im 'planning' on using but if you think there is a better alternative then please let me know as would be gratefully appreciated. I allready have a few bits (head, turbo, cam, pulley, intercooler) but its the block assembly and engine management i need advice on.
Block
2.0 Zetec Block
Reground, balanced and polished crank
Accrilite 86mm Pistons (burton power jobbies)
Farndon Steel H Section Rods
ARP Rod end bolts
Not sure on bearings what can u suggest???
Felpro Head Gasket
ARP Head Bolts
Head
Cylinder Developments Stage 2 Head
Kent CVH 35 Cam
Vernier Pulley
Newmans Solid Lifters
Double Valve Springs
Turbo
T3/T4 Maram Shafted Stage 3 Hybrid Turbo
-34 Actuator
Radtec Front Mount
Approx 20 PSI
Unsure on management, have had gotech suggested, and there is always the old cossie management but what are the other option? (stu @ MD)
Got the obvious like exhaust etc. Will also be using mocal oil cooler, swirl pot, breather system, high pressure oil pump.
Is 300BHP achieveable with the parts i have listed?
Cheers for takin the time to have a read and for the comments
A11OVA
Old Feb 27, 2006 | 11:17 PM
a11ova's Avatar
a11ova
anyone???
Old Feb 27, 2006 | 11:26 PM
Shings's Avatar
Shings
Default Re: Opinions, Advice and thoughts....
Originally Posted by a11ova
Head
Kent CVH 35 Cam
Vernier Pulley
NOPE!
Needs a much better head than that in my opinion.
why go for a 2.0 Zetec bottom end????
Also... cossie management is the way forward again in my opinion.
You cant do somet like a 300bhp RST on a budget of a few grand.. they're expensive bits of kit.
Pound for pound a Cossie is much much cheaper.
Have you thought about a gearbox? It WILL need a STG2+ box from CTS.
Brakes?
Suspension?
All these will need uprating without a shadow of a doubt for proper items.
Also your shell will need to be minter than mint or you'll pull it apart in seconds.
I pulled the cross member off my (Tims) old car with about 280 ish
A true 300bhp at the fly wheel is a big ordeal for these cars.. and expensive.
Hope this helps...
Jake
Old Feb 28, 2006 | 12:01 AM
a11ova's Avatar
a11ova
cheers for the advice. Im not pklanning on building it on a few grand, im looking at throwing in the region of 5k at it. Would havwe a cossie but only a escort. Couldnt see myself behind a sierra lol. Gearbox wil be a gearbox man stage 2 with quaiffe diff, suspension is koni adgustables with poly bushes throughout. Brakes are sorted allready mate....nice set of 4 POT's with 300mm discs
dont want to go full zetec route. what do u suggest with the head???
cheers once again
Old Feb 28, 2006 | 12:35 AM
Talk to Karl norris about the head, he knows lots about 300bhp ZV heads, and frankly most of the rest of us dont, i have no experience of CVH motors at all really, its just not something thats ever interested me, and TBH if i had an rs turbo and wanted 300bhp, i would go zetec turbo instead.
300bhp is a hell of a lot on an 8v head really.
I would be surprised if it comes in at under 5K to be honest when you are finished
Old Feb 28, 2006 | 12:48 AM
a11ova's Avatar
a11ova
cheers chip. will give him a bell in the next few days
Old Feb 28, 2006 | 01:04 AM
LEE-RS's Avatar
LEE-RS
Custom
cvh tunning
http://www.pumaracing.co.uk/cvh.htm
http://www.pumaracing.co.uk/turbo.htm
Old Feb 28, 2006 | 06:42 PM
Shings's Avatar
Shings
cheers once again
5k at the engine alone will prob see you in the right direction...
If I were you the ONLY people I would consider talking to for a CVH head for a 300bhp car is Karl NMS and APT simply because both have produced the goods in a "proven" fashion.
I am SURE there are others out there who could do it but I would want to spend my money with these 2.
Jake
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
