S2 90 spec brakes
Old Feb 27, 2006 | 08:44 PM
mattrst90spec's Avatar
mattrst90spec
Default S2 90 spec brakes
Hi
Got a problem with my brakes on my G plate rst, i cant get any brakes on the rear wheels!!
The front brakes on the car work perfect, but cant even get fluid to the rear cylinders using a pressure bleeding kit!, does anybody know why this?
I hate the abs system anyway & want to remove it all from the car, i have a G plate orion 1.4 scrapper in my yard is there any reason why i cant remove the brake pipes & servo etc from it & put in my rst?
Matt
Old Feb 27, 2006 | 11:39 PM
NUTS RuS's Avatar
NUTS RuS
Do you have the car sat on the ground ?
The rear load compensators may be jammed shut, so no fluid will pass to the drums, they could also be siezed.
Free these up first, then bleed it with the car on the ground.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
