Series1 wot mod next
Old Feb 27, 2006 | 06:56 PM
Paul17's Avatar
Paul17
Default Series1 wot mod next
I was just woundering wot mod to do next to my series1. At the moment its got a sue collins chip on it with the actuator. It's all so got a 285t2 cam, K&N air filter, Full system exhorst. At the moment i know i need an intercooler wot type should i go4 don't want to have to cut out to get it in. And also wot do i want to get after the intercooler
Thanks
Old Feb 27, 2006 | 07:00 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I'd say go for a GRS front mount IC mate, have heard they go on without much bother and do the job even on huge power RST's.
after that i'd look into some head work and an uprated turbo.
hope this helps
Old Feb 27, 2006 | 07:02 PM
Paul17's Avatar
Paul17
wot sort of head work mate. Thing is my cars my daily runner, to work and back and i don't really want to take it off the road for long. when people talk about stage 1 stage 2 stage 3 wot does it mean?
Old Feb 27, 2006 | 07:12 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
depends on the tuner what an exact stage means, but head work involves porting and polishing the head, usually fitting bigger valves & better guides. Just allows more freeflow, 8v head is stupidly restricting.
a head is usually specced to your turbo etc. If you know what you want the car doesn't have to be off the road long, a good idea would be to talk to a tuner NMS, Jampsport, Motorsport Developments etc they'l discuss what you're after performance wise and once booked in should have ot done pretty quickly.
Old Feb 27, 2006 | 07:26 PM
Paul17's Avatar
Paul17
My car's going to msd on sat cos it's got a problem when you accelorate te car cut's out the rev counter drops and then it comes back in. Wots the difference between a intercooler and a chargecooler?
Old Feb 27, 2006 | 07:32 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
fundamental difference is one cools with air one with water...
go for a big intercooler IMO mate, makes life easier and will be cheaper overall.
Old Feb 27, 2006 | 10:36 PM
Paul17's Avatar
Paul17
that grs intercooler looks smart especially with that Fan How much are they?
Old Feb 27, 2006 | 10:40 PM
addiction's Avatar
addiction
www.grsmotorsort.co.uk
Old Feb 27, 2006 | 10:55 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
Or even better try this
http://www.grsmotorsport.co.uk/
Old Feb 27, 2006 | 10:57 PM
addiction's Avatar
addiction
oops spelt it wrong
Old Feb 27, 2006 | 11:01 PM
a11ova's Avatar
a11ova
i have a radtec front mount and as regards to your car cutting out, sounds as tho the chip aint doing its job. thats the ecu cutting power due to your car hitting the factory ste boost limit. Stu and the boys should be able to sort it for ya mate
Old Feb 28, 2006 | 04:49 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
pretty sure that wouldn't cut out the engine, would just pop and bang on boost but fuelling defo needs sorting you're right
Old Feb 28, 2006 | 06:20 PM
Paul17's Avatar
Paul17
why do chips go fucked? cos the car's been chipped for a few years and it's run fine till just christmas. thing is it doesn't cut at a sertain ammount of boost, it'll cut out at 0 boost and it'll cut out at 1.5 bar of boost there doesn't seem to be a certain ammount, plus i,ve changed the ecu to a standard one and it does the same and i've turned the boost down and it makes no difference
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
