boost probs
Old Feb 27, 2006 | 03:06 PM
barry0777's Avatar
barry0777
Default boost probs
hi all again
just done my convertion rst in my van and it all starts and runs fine but it only bossting half i think when iput my foot down it pull alittle and then backs off flat
it has actator
s/s
k&n
bleed valve
chip
it has a dump vlave which dumps fine but it also makes a flicking sound what is that and why is it doing that al;l starts and drivs fine but have also changed the meter unit will this effect any thing as it was set up at the rollers before it when in my van can anyone help???it anoying to dive???thanks
also when ireternd from the dive the exh man was glowing red hot
Old Mar 1, 2006 | 08:26 PM
Number1's Avatar
Number1
Good luck finding this one out mate, my cars doing the same on full throttle and it's a nightmare trying to figure out why.. try taking off the dump valve, thats what i did as a process of elimination and found out that it runs better! charge temp sensor also might be worth checking, check all electrical connections as well
Best of luck!
Dave
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
