Oil pressure ? Question
Feb 26, 2006 | 11:25 PM
A car i know with a fully rebuilt bottom end 22000 miles ago has an oil pressure reading of 20 psi @ 2000rpm and 9psi @ idle ? Has been checked for restrictions from the turbo and has had new shells one week ago ? Oil light still coming on @ junctions etc, could it be topend work needing done ? i wanna get it soted, any help - cheers
Feb 27, 2006 | 10:51 AM
What oil are you using? Did you measure the crank etc to see what shells it needed?
Dave
Mar 5, 2006 | 06:41 PM
did you renew the oil pump? or at least oil pressure valve?
thats very low oil pressure, you shouldnt drive in that condition..
good luck
Mar 5, 2006 | 07:47 PM
Mar 5, 2006 | 08:14 PM
Mar 5, 2006 | 08:25 PM
At LEAST 1 bar @ idle.
At 2000rpm I see 2.5bar @ 100°c
Mar 7, 2006 | 12:00 AM
New everything m8 2 new pumps - 3 new switches - full rebuild..what more can i say.
Mar 7, 2006 | 12:01 AM
valvoline turbo V oil m8 - changed evry 3000
Mar 7, 2006 | 12:05 PM
checked the gauge?
Also, block of the oil feed to the turbo as a test. Often it can bleed away the pressure reading.
Mar 7, 2006 | 12:07 PM
Not something silly like oil pickup blocked or something?
Mar 9, 2006 | 08:25 PM
checked all that guys -
155lee
Oct 27, 2015 04:55 AM
Kam B
Sep 24, 2015 10:40 AM
dombanks
Sep 21, 2015 08:38 PM
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
