clock removal
Old Feb 26, 2006 | 08:02 PM
Cozzie Bhoy's Avatar
Cozzie Bhoy
Default clock removal
The pin that holds the rev clock needle at 0 has fallen out of my clocks unlike the saff where you can just unscrew the front of the clocks and put it back on the escy seems to be sealed. Any tips on how to get it back on ? I tried keyhole surgery though the reset button hole but it was near immpossible to do.
Old Feb 26, 2006 | 08:56 PM
THE RADMAN's Avatar
THE RADMAN
the front part just clips on mate but you will have to remove the whole unit to get at clips,there is also a bulb that needs removing from the top before it can be unclipped
Old Mar 2, 2006 | 09:32 PM
Cozzie Bhoy
Cheers Radman , Bet i'll graze a few knuckles try'n to disconnect the speedo.
Old Mar 5, 2006 | 01:46 PM
Cozzie Bhoy
Sorted it. Fookin thing was wreckin my head. Hey Radman, What were you doing stripping down you clocks anyhow ???
Old Mar 5, 2006 | 01:51 PM
Damo V's Avatar
Damo V
probably to change the inverter
Mark_
14
Jan 16, 2016 05:27 PM
Orion_Gav
Sep 29, 2015 04:50 PM
Mr S1
20
Sep 27, 2015 04:06 PM
