piston rings
Old Feb 26, 2006 | 07:01 PM
indy992000's Avatar
indy992000
Default piston rings
hi people i need to change my piston rings and was wondering do i need to have a rebore or can i just stick new piston rings in.if the block was worn could i stick over sized rings in or what
Old Feb 26, 2006 | 07:51 PM
Alvyn's Avatar
Alvyn
get the bores checked you MAY get away with just having to hone the bores!
Old Feb 26, 2006 | 09:53 PM
Avinitlarge's Avatar
Avinitlarge
and whilst we are on the subject, Measuring the bores, No lip at the top or bottom but there could be in the middle, Thats where there is most thrust due to conrod being at an angle at that point, It may look ok at the top and bottom but the middle of the bore could still be worn. I forgot what you use to measure the bore, Internal calipers??
Old Feb 26, 2006 | 10:02 PM
bud-weis's Avatar
bud-weis
Football Cwazy
you should have your piston to bore clearances checked, and then see if a re-bore is needed, if so then you'll need new pistons and rings.
you may get away with a hone, but you can't fit oversized rings to std sized pistons.
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
