Help.....Needed asap!
Old Feb 26, 2006 | 06:12 PM
a11ova's Avatar
a11ova
Default Help.....Needed asap!
right im looking at fitting my new T3/ T4 hyrbid tomorrow but something has just dawned on me!!! The metering unit to turbo hose wont fit on the turbo!! What do i need to do?? What diameter pipe do i need to get it to fit?? anyone know where i can get one from asap??
cheers for the help all
Old Feb 26, 2006 | 09:20 PM
zippyobrien's Avatar
zippyobrien
i had this prob mate, sfs made a hose up for me, might still have the mould, give them a bell,
on a side note, what spec are you running, i only ask because your sig says 210 @ 20psi, i assume youve had no head work,
this will make the car aan absolute pig to drive, and 20psi with a t34 is to much for a standard bottom end and mfi management (unless u get fith injector or bored out meterring head
Old Feb 26, 2006 | 09:41 PM
a11ova's Avatar
a11ova
Shot peened Rods
Forge Low Comp Pistons
Cylinder developments stage 2 head
CVH 35 cam
Vernier Pulley
-34 actuator
Radtec Front Mount
Collins Chips
Mongoose System
K&N
Magnecor leads
20psi
T3 Hybrid Turbo
also says approx so could be more could be less, will tell u what it makes on friday with the t34 on as its geting setup at noble motorsport
Flatlinedan
Sep 18, 2015 12:41 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
syathome2000
Jul 27, 2004 01:32 PM
Fudgey
Jul 21, 2004 10:11 PM
