General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
T34's usually have the fitment that is cast into the comp housing, if you want to fit it onto a 2wd application then the housings need to be rotated,and thus the factory holes for the actuator don't line up with the wastegate arm, so a new bracket is needed.
he might have one thats had the extra one chopped,,,,,,, ive just done that to mine as i dont wanna have extra weight over the front wheels as a way to reduce understeer
it's a T34 and it looks just like the pic i showed above
only difference is mine has the extra actuator bracket because mine's fitted to a 2wd exhaust manifold, yours is fitted in the standard position for a 4x4 manifold
