standard header tank?
Old Feb 26, 2006 | 11:45 AM
cahzz's Avatar
cahzz
Default standard header tank?
is the standard tank prone to cracking?? mine is getting some slight grazes which look like cracks from the inside?? is this a common thing and why you all go to an alloy unit instead?
Old Feb 26, 2006 | 11:47 AM
THE RADMAN's Avatar
THE RADMAN
yep it is
Old Feb 26, 2006 | 11:54 AM
cahzz's Avatar
cahzz
ok, i was going to source a new standard headertank but if they are renouned for cracking then i'll replace it with an alloy one,
as ive come from turbo renaults when i drained the cooling system i used to bleed the cooling system with bleed nipples on the pipes? how does bleeding the cooling system work in the cossie? do i need to bleed it, as some are self bleeding?
sorry for all the questions, just cant wait to get stuck in?!!
Old Feb 26, 2006 | 11:55 AM
cahzz's Avatar
cahzz
whats the best alloy header tank available?
Old Feb 26, 2006 | 12:03 PM
Rippers's Avatar
Rippers
Monte Geek
Bailey IMO
Old Feb 26, 2006 | 12:06 PM
cahzz's Avatar
cahzz
paul your always their to answer the questions!! lol
quality!!!
Old Feb 26, 2006 | 12:13 PM
Redkop's Avatar
Redkop
AFAIK the Bailey one doesn't have a sight glass. I prefer the Spec-R one which does.
Old Feb 26, 2006 | 12:24 PM
THE RADMAN's Avatar
THE RADMAN
ggr, my bailey one split
Old Feb 26, 2006 | 12:26 PM
maxest's Avatar
maxest
I like the pro-alloy one's
Old Feb 26, 2006 | 12:49 PM
Rippers's Avatar
Rippers
Monte Geek
Originally Posted by THE RADMAN
my bailey one split
first case I've ever heard of
Do agree on the Spec-R one having the sight glass being good but the welds look so home made to me
When I get around to it I'll have all Bailey tanks anodised black
Old Feb 26, 2006 | 12:52 PM
cahzz's Avatar
cahzz
funny you should mention that what about proalloy's units, they have sight glass and also come in stealth mat black, they look quality tbh!!
Old Feb 26, 2006 | 01:23 PM
THE RADMAN's Avatar
THE RADMAN
where the alloy "lid" is scored during production to mark it out is where mine split,presumably the yrs of expansion and contraction found this as the weak spot and it opened up and split straight along the score lines,just above the welded section,maybe it was scored a bit too deep in the first place? not what you want happening though the score lines are inside the tank by the way so you cant exactly keep an eye on them
Old Feb 26, 2006 | 01:59 PM
cahzz's Avatar
cahzz
hmmmm, quite worring tbh radman
when you think the original ford item has lasted years, and its plastuc, makes you think its probably the better item.
Old Feb 26, 2006 | 02:00 PM
Rippers's Avatar
Rippers
Monte Geek
Sounds quailty
Old Feb 26, 2006 | 02:52 PM
cahzz's Avatar
cahzz
paul they look awesome to be fair
i'll post a link in a sec
Old Feb 26, 2006 | 02:56 PM
cahzz's Avatar
cahzz
http://www.proalloy.co.uk/cgi-bin/si...19&id=proalloy
mmmmmmmm lovely
cahzz's Avatar
cahzz
not the best example but looks lovely doesnt it?
Old Feb 26, 2006 | 03:04 PM
Rippers's Avatar
Rippers
Monte Geek
beautiful bernard! I wonder if they do them anodised?
Old Feb 26, 2006 | 04:05 PM
Redkop's Avatar
Redkop
Here's a better pic.... http://www.proalloy.co.uk/cgi-bin/si...98&id=proalloy
Looks good I need to get something sorted soon, as I am on my 3rd standard one and that is cracked too.
Old Feb 26, 2006 | 04:11 PM
cahzz's Avatar
cahzz
red really?? your third one???!!!!!??? what type of power are you running? mine is standard so it shouldnt stress it as much as yours!!!
great pic by the way!!
Old Feb 26, 2006 | 04:12 PM
cahzz's Avatar
cahzz
were after the new stealth ones, would look awesome with some carbon bits!!
Old Feb 26, 2006 | 04:14 PM
Redkop's Avatar
Redkop
About 380bhp... the first one went when car was almost standard and this is the 2nd since running more power.
Old Feb 26, 2006 | 04:24 PM
cahzz's Avatar
cahzz
christ, bet they arent cheap either, where are you gettign them from, maybe a shitty batch??
Old Feb 26, 2006 | 04:28 PM
Redkop's Avatar
Redkop
Getting them from Ford dealer. It's well known that they star/crack though. First one I got about 4 years ago was Ł14, they're over Ł30 now.
Old Feb 26, 2006 | 04:40 PM
cahzz's Avatar
cahzz
so they are still available then? mine has what i can only describe as tiny little cracks, stress cracks, it looks like at one time it may just explode!!
defo dont want that, when youve changed yours int he past, could you give me some tips abput bleeding the cooling system, do you need to firstly or is it self bleeding?
Old Feb 26, 2006 | 04:57 PM
Redkop's Avatar
Redkop
Yeah mine are stress cracks from getting too hot. I'm afraid I haven't a clue how to go about changing one.
Old Feb 26, 2006 | 06:44 PM
MATCOS's Avatar
MATCOS
I got one 6 months ago and it was Ł26 from Ford-at that price you can afford to change them nearly 10 times before you get into Spec R with sight glass prices My last one stayed on the car from new-the only reason I changed it was because it was discoloured, I run a MAD stage 4 by the way
Old Feb 26, 2006 | 07:02 PM
THE RADMAN's Avatar
THE RADMAN
theres a bolt on the top of the stat housing for bleeding,but you prob wont need to anyway
Old Feb 26, 2006 | 08:03 PM
cahzz's Avatar
cahzz
top banana their matey!!
i really need to buy a haynes manual tbh
Old Feb 26, 2006 | 08:53 PM
THE RADMAN's Avatar
THE RADMAN
haynes dont do one mate,but plenty of the volume 1 +2 cossie manuals about,normally some on e bay
Old Feb 26, 2006 | 09:08 PM
Redkop's Avatar
Redkop
The ProAlloy one is only Ł165 inc sight glass.
Old Feb 27, 2006 | 10:43 AM
Dave Henshall's Avatar
Dave Henshall
std looks better IMO - as long as it new and clean and you have draind and refilled with new antifreeze - and at 25 quid for a new one - it does look nicer uner there IMO -
Old Feb 27, 2006 | 05:16 PM
Damo V's Avatar
Damo V
I'm with Nick, GGR/Tarcal IMO
Old Feb 27, 2006 | 08:18 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
Guys..,we may be doing a promotion on STEALTH tanks soon
we really want to push these as they look so cool!
Old Feb 27, 2006 | 09:23 PM
cahzz's Avatar
cahzz
do me a promo deal and i'll give you my money tomorrow
Old Feb 28, 2006 | 07:27 AM
Dave Henshall
what does s stealth tank look like..?
Old Feb 28, 2006 | 07:55 AM
MONSTER's Avatar
MONSTER
Its painted black instead of polished.
Old Feb 28, 2006 | 08:02 AM
Dave Henshall
ah, like mike rainbirds...?
Old Feb 28, 2006 | 08:15 AM
wayneclayden
590 BHP/Ton
Similar...
They are powder coated with satin matt black. Martoon and Porkie are having theirs done at the moment-they look propper
Old Feb 28, 2006 | 08:19 AM
Dave Henshall
cool, may look quite good actually match the battery cover, heat shield, ,cam belt cover and air box lid - nice
