UNDERSEALING QUESTION??........
Im about to underseal my white rs turbo fairly soon there are a few areas of surface rust but nothing major that i can see so how do i go about sorting these areas first before i underseal it, also im thinking about using waxoyl in the spray/pump variety is this any good..many thanks again peeps
......also how long should it take to do all the underside???
......also how long should it take to do all the underside??? Too many posts.. I need a life!!
imo i wouldent underseal it as that will trap any dirt and water , with the rust side of things its best to grind them down and treat them with a rust treatment to stop them going again, then etch primer over that , take a look at some of the resto's going on thats the best idea.
