Simple MS-DOS commands! HELP!
Ive not used MS-DOS for like, 8 years at least i reckon, and have totally forgot how to use it
Got a couple of old games i wanna play, and will only work in MS-DOS mode, but im fucked if i can remember the functions to even load the games
How do you search the directorys for a file? I cant remember.
And how do you go into a directory for that matter
Actually, how you do all those simple things, i cant remember shit
There are MS-DOS help sites on the net, but they all complicated, i only need the majorly simple stuff just to search and load a couple of games...
Ages since ive used it but this is what i remember (right or wrong). . .
CD.. Goes back to original directory
dir shows contents
dir/w shows contents spread
c:\ to go to c drive or maybe cd c:\
when in the directory open its contents with dir and look for the .exe file and type its name to load it
dir shows contents
right, i worked out "cd" then a space, then the folder name goes into that folder.
but couldnt remember how to pause the "dir" function to see whats in big folders, but thats that dir/w thing isnt it? it was summat like that.
either way, i got it working enough to play Jet Strike
Good old 1994 games
no sound tho
says cant find a sound card
gotta get ready to go out now anyhow so thats enough for now, cheers
Good old 1994 games
no sound tho
Depends what version of dos and what OS/Hardware you run.
For 8 years i used DOS 5 or 6 along side Windows 3.1 (you could choose to load it in dos, none of this direct loading into XP business) before upgrading to win98 in 1999
I still remember some functions, the main ones you need are the ones above really. For searching directories or whole disks with the contents spread on Dos5/6 the command is: "dir|more". You never mentioned what Dos version your using btw, probz will be why the sound aint working as some of the games were designed to be playe din dos 5/6 and not windows XP version dos so the drivers/setting were different
dir/s - shows directories and all contents
dir/p - shows contents of current directory page-by-page
dir/s/p - shows directories and all contents, page-by-page
cd.. - back one directory
cd [directory name] - opens that directory
doskey - turns on the ability to scroll through previously entered commands
Alternatively type 'help' for a list of commands......
Ronnie Scott
Sep 20, 2015 10:21 PM
