Fitted boost guage, now dump valve is delayed?
hi i fitted my boost guage earlyer and now the dump valve has a delay in going off. hav i connected it wrong? i hav 2 T pieces coming off the pipe from the ecu now. Its on my series one by the way
Originally Posted by Freddy_mercury_magic
just take the dump valve off... problem solved!
Dumpvalves protect the turbo, don't cause running problems ever and also help combat global warming.
How did i know you'd pop up on this thread
stop being knobs and help the man
i personally never noticed any timing delay after fitting my boost gauge, but it was Yago, and the dump valve is gone know
cant think why though, unless u have a leaky gauge
Your meant to take the dump valve and boost gauge from the left had side of the phlem because if you eva have a problem with the dumpvalve or boost gauge ie. any leaks they could give a false reading to the ecu about how much boost there is and damage your engine
I have seen the d/valve hose fitted on the other side of the manifold tho...
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
