1.9CVH, Where do I go now!!......Managment?
Old Feb 24, 2006 | 07:04 PM
chaps100's Avatar
chaps100
Default 1.9CVH, Where do I go now!!......Managment?
Hello guys I bought stevenEBM's 1.9cvh off here,
Its a Escort Turbo Engine and currently fitted to my MK1 Fez,
I was wondering what sort of max boost should it safely run?
I have been told that the 195bhp chip makes the 1.9cvh engines run lean?
Im hardly running any boost just now, what route should I go?
Managment?
Bleed valve or stay with the AMAL valve?
Heres the spec of the engine:
1.9cvh
balanced 88mm cast iron crank
forged connecting rods
hi duty big end bearings
floating small bearings
83mm mahle pistons
hi flow oil pump
stage 3 head
double valve springs
bronze valve guides
hi flow water pump
fast road cam.
ava print out at 200bhp at only 14psi
Looking at maximum reliable power.
Thanks
Nick
Old Feb 25, 2006 | 11:23 AM
a11ova's Avatar
a11ova
neither....gotech engine management
Old Feb 25, 2006 | 12:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
What management is on it now?
OFAB & C are fine when mapped properly.
Old Feb 25, 2006 | 04:54 PM
Stoo's Avatar
Stoo
That engine was fit to run up to 19psi as it had fuel mod's done by AVA..but,you dont have the Fuel ECU do you?
Thats a good strong engine you have there chap!
Old Feb 26, 2006 | 10:42 AM
chaps100's Avatar
chaps100
Dont know what mangement!! I think it is just standard!
Can I still get the standard set up mapped?
Old Feb 26, 2006 | 11:17 AM
szabyk RST's Avatar
szabyk RST
83mm mahle pistons
typ??
thanks
Woolley
Mar 2, 2014 07:45 AM
Canada1
Dec 18, 2010 09:28 PM
FULLBORE
Jul 12, 2008 10:16 PM
FULLBORE
Jul 11, 2008 10:28 PM
