Zetec Spark Plugs and HT Leads
Old Feb 24, 2006 | 02:47 PM
sjoyce666's Avatar
sjoyce666
Default Zetec Spark Plugs and HT Leads
Ive recently had my fiesta converted from a 1.6 to a 2.0
The engine is still using the spark plugs that came with it so id like to change them
What are the best plugs for a 2.0 Zetec. Its a phase 1 or 2 out of a Mondeo if that helps. Also what are the best leads to accompany them
While im here what are the best plugs for a 1.6 Zetec as my brother is in need of some too
Scott
Old Feb 24, 2006 | 07:56 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
loads to choose from mate i would recon fro semi standard motor ngk platinum plugs around about 40 set as for leads same again loads but i chose megacore leads
hope this helps
Old Feb 24, 2006 | 10:25 PM
sexr3i's Avatar
sexr3i
isn't it
I'm using magnecore kv8 leads and ngk copper core plugs on a mildly tuned zetec atm. are absolutely spot on for me. Would highly recommend.
bear in mind zetecs had pretty good plugs and leads from ford, so must be decent or you'll get hassle.
DixieTheKid
11
Jun 6, 2020 11:20 AM
steve.rst
Mar 15, 2016 08:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
pabloXR
Sep 21, 2015 12:42 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
