Engine Block Paint Where From???
I want 2 paint my block now its out of the car and want a blue similar 2 the blue that samco use on there hoses.
Any ideas where 2 get this from?
cheers
cheers
I use radiator paint from B&Q
Providing the block is perfectly clean it will not peal off at any temperature its safe to let your block get too.
Useful for if you build an engine and someone runs it without water and badly overheats it though, cause it comes off then!
Available in ANY colour, literally take something you want it matched to and they will mix it apparently, although i always just buy the "off the shelf" red one personally.
When you use it the colour changes a bit when it first gets hot so dont worry if it doesnt look exactly the same as its supposed to.
big_Rad
Sep 15, 2017 09:36 AM
James Porter
Oct 28, 2015 12:17 PM
Zoggon
Aug 10, 2015 10:39 AM
