cossie brakes on a mk 6/7 escort question
Old Feb 23, 2006 | 05:57 PM
GUZZLER's Avatar
GUZZLER
Default cossie brakes on a mk 6/7 escort question
whats the easiest way? i have a set of 4x4 calipers & 2wd disks, do these go on as easy as the fiesta/escort turbos??
i know the brake lines have different ends, do the new lines have to be made up or does someone sell them off the shelf?
thanks in advance.
Old Feb 23, 2006 | 06:00 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
use cossie braided lines mate.
the calipers need spacing about 5mm for them to fit centrally over the discs.
a few 10mm washers sorts that.
i had no probs running mine like that for over year.
HTH
Old Feb 23, 2006 | 06:02 PM
GUZZLER's Avatar
GUZZLER
cheers Dan
so the 4x4 caliper 2wd disc combo is ok then
Old Feb 23, 2006 | 06:08 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
I did what fudgeass says and used the washers. I had to drill the hub out from 8mm to 10mm. but I used Escort Cosworth discs and callipers so maybe it’s different.
Old Feb 23, 2006 | 06:15 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i didnt need to drill anything
i used 4x4 discs and calipers
Vincereese
Jun 1, 2023 09:14 AM
mrice0107
Aug 21, 2015 07:55 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Red_bull
Aug 9, 2015 08:34 AM
