best dump valve
Feb 23, 2006 | 02:05 PM
best dump valve
what is the best dump valve to use on a small or big turbo cossie.
Feb 23, 2006 | 02:07 PM
Feb 23, 2006 | 02:08 PM
p.s. i think its a 'piston type'
Feb 23, 2006 | 02:10 PM
Feb 23, 2006 | 02:13 PM
Feb 23, 2006 | 02:14 PM
The Standard one is best for the ST for a few reasons.
NEVER take it off the ST type, ignore the poor advise on this post in that direction
Feb 23, 2006 | 02:16 PM
Depends how long you want your turbo to last....
Dump Valves are fitted for a reason..... And it ain't the Pssstttttchhhhh noise either.
Feb 23, 2006 | 02:21 PM
see.....told ya!!!! NEVER listen to what i say!!!
Feb 23, 2006 | 02:28 PM
Chatter all the way.. sounds much harder
Keither, did Wapster force you to have MOIST in your sig?!
PS: I have a large turb lol
Feb 23, 2006 | 02:44 PM
no....its just me FAVORITE WORD!!!
Feb 23, 2006 | 02:50 PM
His too. Was stuck to his bedroom door for years.. probbaly still is now lol
Feb 23, 2006 | 03:45 PM
so no dump valve it is.ok cheers
Feb 23, 2006 | 03:49 PM
Quote:
MOIST!!
Feb 23, 2006 | 03:50 PM
Feb 23, 2006 | 03:53 PM
If you listen to Stu, its a bad idea to remove the std DV from a ST, think to do with the AFM.
But actually, knowing where the DV is on a standard ST, i doubt you will notice it actually already has one...
Feb 23, 2006 | 03:54 PM
im talking about a small turbo cossie stu.not a st.
Feb 23, 2006 | 03:55 PM
S mall
T urbo
ST= Small Turbo
Feb 23, 2006 | 03:56 PM
too slow wee man
wee man
when will you learn
Feb 23, 2006 | 03:57 PM
Feb 23, 2006 | 03:58 PM
oh sorry.lolo ha ha carry on carry on ...im scottish.so im alittle slow.lol
as is chop
Feb 23, 2006 | 03:59 PM
Tis Chops excuse too
And yes, I did see that Dave posted that too
Feb 23, 2006 | 04:00 PM
cola
didnt you say on the other post you were going home?
jenni
where you from?
Feb 23, 2006 | 04:26 PM
lampchop im from dundee and steve is edinburgh
Feb 23, 2006 | 04:29 PM
Correct, teh un dumped air on one equipped without one flows through the airflow meter backwards... the AFM has no sense of direction so adds fuel for teh air it saw pass through it....
Same problem occurs when folk fit an aftermarket one as WELL as the std one... all the dumped air has fuel added into teh cylinders for it.
+ The turbo response will be poorer if you remove teh standard one as it actually exits directly onto the compressor blades. very nice design indeed.
where is the p in lamBchop?
im from aberdeen
Feb 23, 2006 | 04:30 PM
lampchop im from dundee and Steve is edinburgh
Explains everything.
We should never have let you lot have your freedom
Feb 23, 2006 | 04:32 PM
pmsl
Feb 23, 2006 | 04:33 PM
Does anybody else remember that dirty great think Keith had on his S1 that looked like a pair of megaphones taped to it?
shut it you tart
Feb 23, 2006 | 04:37 PM
sorry for mistake lambchop.lol.the hunt is on for a small turbo cosworth!!!!!!!!!!!!!!!!!!!!!
Feb 23, 2006 | 04:43 PM
Quote:
p ?
im from aberdeen
there it is!
glad to be of service
Feb 23, 2006 | 04:49 PM
Feb 23, 2006 | 06:37 PM
can some one explain how the ST dump valve works? does it recirc of vent to the atmosphere, just silenced?
Feb 23, 2006 | 07:09 PM
Quote:
p ?
im from aberdeen
there it is!
LMAO
you forgot my
infact i deserve more than one
Feb 24, 2006 | 07:19 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
