strange noises
Old Feb 22, 2006 | 10:17 PM
rapidcossie's Avatar
rapidcossie
Default strange noises
Finally got round to fitting a RS500 GGR induction kit to my car today and it now makes very strange noises.
it chips like crazy anything above half a bar of boost and sounds like darth vader breathing at almost every gear change.
i know the air box is a silencer but i didnt expect this much of an increase in noise
Also, why does the car chirp then dump??
Its a GGR dump valve.
any ideas folks??
Old Feb 22, 2006 | 10:19 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Chirps and dumps as the dumper dont flow enough air to let it all out, so some still comes out the turbo and chatters.
Tis normal, I remember I was shocked at th amount of noise at first.
Take off the dumper and itl be extra extra crazy loud, tho maybe not a good plan, depends how much faith you have in your turbo.
Old Feb 22, 2006 | 10:32 PM
rapidcossie
it will be so loud on a full boost change it will be mental.
dont like it or dislkie it just wanted to check that everything seems ok.
turbo should last ok but will leave the DV on.
do certian DV flow more air??
would two DV's help this?
Old Feb 22, 2006 | 10:57 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
GGR dump valves are one of the better ones.
Spring strength is another thing that will disctate how long they open for, so hence how much they flow.
2 would flow more, but might do more bad than good, ie dump our more air than needed, so worse throttle responce.
Stick with what you got IMO
Old Feb 22, 2006 | 11:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
what turbo do you have??
Old Feb 22, 2006 | 11:01 PM
rapidcossie
turbo is a T4
Old Feb 22, 2006 | 11:28 PM
bud-weis's Avatar
bud-weis
Football Cwazy
thought so, T4 is one that people recommend to always use a dump valve of some kind
Old Feb 22, 2006 | 11:58 PM
Holty's Avatar
Holty
Euan mine makes all sorts of crazy noises running the same kit with and without dump valve. DV is off as i prefer the full chatter
Old Feb 23, 2006 | 06:33 AM
rstoughy's Avatar
rstoughy
Mine makes loads of noise as well its running a 500 GGR cone filter and no dump valve using a T34. Didnt like it at first but you will get used to it.
I was going to stick back in a standard air box but the car has a mirror image catch tank in the space
Old Feb 23, 2006 | 12:52 PM
rapidcossie
ok boys...car is out tonight so will seeifi an get used to the new noises
Old Feb 23, 2006 | 12:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Euan,
boy-racer . Don't let the AVA boys see that cone filter - you'll NEVER live it down .
Bet it's off within a week .
Old Feb 23, 2006 | 04:56 PM
rapidcossie
Euan,
yeah true mike!
start of the spec sheet now is k+n induction kit
Alan and Colin will love that!
hurry up anf move your ass with the escos boxes and il have one!
gingeRS
17
Oct 2, 2015 09:42 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
rsturbo27
Sep 5, 2015 05:08 PM
