Fitting an secs monitor.
Old Feb 22, 2006 | 07:55 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Fitting an secs monitor.
Getting someone to do the soldering part,is the loom long enough to fit in the car 1st then solder or solder it in 1st then fit it into place ?
Old Feb 22, 2006 | 07:59 PM
dave cos4x4's Avatar
dave cos4x4
just don't plug the connectors on to the control panel.
Old Feb 22, 2006 | 08:01 PM
KSA-Cossie's Avatar
KSA-Cossie
That was my plan dave just wanted to know how other folk have done it. Just need to suss out how to remove the ecu and glovebox now.
Old Feb 22, 2006 | 08:13 PM
dave cos4x4
give the glove box a good pull and it will pop out.
the ecu will unplug .
be a good bit of length on the wiring harness to sort the soldering out on it.
Old Feb 23, 2006 | 06:24 AM
KSA-Cossie's Avatar
KSA-Cossie
Many thanks dave.
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Bailes1992
Aug 16, 2015 07:14 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
