What power will this engine make ?
Old Feb 21, 2006 | 10:51 PM
david's Avatar
david
Default What power will this engine make ?
1.8 zvh with STD pistons and no decomp plate, lightly ported xr3i head, unchipped OFAC ecu, T3 turbo, S2 rad and intercooler, stainless exhaust,cossie cone filter.
How much do you all reckon then ? ive got a figure of around 140ish in my head is that right ?
Also what boost does OFAC run at when standard ?
Old Feb 21, 2006 | 11:01 PM
T28 RST's Avatar
T28 RST
Ok then
Prolly about right with your figure
Old Feb 22, 2006 | 12:05 AM
david's Avatar
david
Davy what would you reckon on the same engine but 195 chip, beige injectors, 14-15psi boost, 2wd cossie intercooler oh and some ARP rod bolts just to be on the safe side
Old Feb 22, 2006 | 12:08 AM
thelynx's Avatar
thelynx
Default Re: What power will this engine make ?
Hmmmm what compression is that gonna be running then? NO decom plate and standard pistons!!!!How much boost ?
Old Feb 22, 2006 | 12:15 AM
david's Avatar
david
It should be high enough to give me a laugh
Mate of mine runs the same bottom end setup in his S2 on k-jet with no problems so far
Old Feb 22, 2006 | 12:18 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
fuck all, you put it together what did you do with that low comp bottom end?
david's Avatar
david
Good point
Old Feb 22, 2006 | 09:24 AM
twinkle_2k86's Avatar
twinkle_2k86
sounds almost the same set up as me,
im going to be running,
1.8 ZVH, with 30thou machined off pistons
Collins chip
Hybrid T3 turbo
Dash 31
2wd Cossie intercooler
Stianless exhuast
K&N panel filter in drilled airbox
Fuel mod for MFi
and in going to run about 14 to 16 psi.
and im hoping for about 200bhp.
Old Feb 22, 2006 | 04:48 PM
ivorbiggun's Avatar
ivorbiggun
Almost the same?!!! .75 mm off the top the pistons.
14/16 psi of boost/almost the same as standard?
Old Feb 22, 2006 | 04:50 PM
ivorbiggun's Avatar
ivorbiggun
Almost the same as my Orange P7....
Old Feb 22, 2006 | 05:07 PM
Kop2381's Avatar
Kop2381
I had a 1.8zvh on std pistons Stage 2 head running 6psi just a whiff of boost and it made 160bhp solidly ran solidly still going strong i beleive
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
IAN RS2k
Aug 18, 2015 07:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
