EDIS-4 GREEN/YELLOW wire??????????????????????
Old Feb 21, 2006 | 09:07 PM
FULLBORE's Avatar
FULLBORE
Default EDIS-4 GREEN/YELLOW wire??????????????????????
i have converted a mk3 to frst power! i went to start the car and it was turning over and thats it.under inspection i noticed i was not getting a spark.i changed the cps and checked EVerything was all plugged on correctly.The coil pack is fine and is getting power. Then under inspection of the loom i noticed that on the plug that connects to the EDIS-4 unit,the GREEN/YELLOW wire is broke.i took all the at off that part of loom hoping to find the other bit of wire so that i could re-connect this...................................But it wasnt there?? i checked the plug ends to find where the wire goes to but cannot see it on the end of ANY plugs.i checked to see if the cps was getting a live feed and it wasnt??? ive since been told that the cps doesnt work off of a live feed!!! is this true???
IF SOMEONE COULD PLEASE tell me what this wire does and where it goes i would be very very very happy again.im starting to get very disheartened as i know ive done everything right and the fu#kinm thing still wont start!!!!!!!!!!
Old Feb 21, 2006 | 09:53 PM
jayRS's Avatar
jayRS
the crank sensor should have a blue/yellow (pin 5 on EDIS) and a blue/green (pin 6 on EDIS), the blue/green will have a brown ( pin 7 on EDIS) branched into it by the edis.
the only thing i can see about a green and yellow wire looking in the haynes is on 1.1,1.3 CFI and 1.4 CFI 91 on and thats pin 12 on edis,
on FRST ( and 1.8 dohc) pin 12 is green on its own, but it goes to ignition coil, same as 1.1 etc, and in the same place (out side pin, doesnt say which one) how ever the FRST has 2 green wires, 1 goes to each outer pin of coil, 1.1 etc have a green/yellow and a green and red.
i know this may not be what ya asking for mate but from what im looking at the FRST doesnt have a green/yellow wire,
are you sure you have the right loom for the ecu your using ? ofab ecu and ofac loom for example,
as for the queston on the CPS..........
Old Feb 21, 2006 | 10:01 PM
jayRS's Avatar
jayRS
dunno why its small? have tried to enlage and post again but it wont have it for some reason
Old Feb 21, 2006 | 10:54 PM
FULLBORE's Avatar
FULLBORE
my mate has got a H plate fez rst and he has a green/yellow wire in the same place as mine??? i dont know what the pin no is,but with it plugged in,if you were looking at the edis module from the the front of the car,it is one in from the left???? my mate doesnt want to unwrap his loom(i dont blame him) so that we can see where it goes.
when i took the looms out(as ive got a frst in car loom aswell) the car i took it off was working properly,its only when mine wouldnt start that i noticed the broken wire!!!!
Old Feb 21, 2006 | 11:01 PM
jayRS's Avatar
jayRS
mine has a green and yellow wire also, but i was going on a haynes manual....
this wire should go to the coil mate..
i would check the edis itself, and the CPS again mate.
Old Feb 22, 2006 | 06:28 AM
FULLBORE's Avatar
FULLBORE
i will do tonight after work,i will let you know how i get on mate.cheers
Old Feb 22, 2006 | 09:13 PM
jayRS's Avatar
jayRS
just a thought mate, have you got a plug in chip? if so take it out and try it then, might be the chip
Old Feb 23, 2006 | 04:33 PM
FULLBORE's Avatar
FULLBORE
no mate.aint chipped. ive had a look and it dont go to the coilpack plug. on the coil pack plug ive got a Green,a black and a light green?????
Old Feb 23, 2006 | 05:31 PM
jayRS's Avatar
jayRS
can you get a pic of what wire you talking about? ive seen some looms with a wire connected to another via a scotch lock for some reason, maybe yours need it?
Old Feb 23, 2006 | 06:39 PM
FULLBORE's Avatar
FULLBORE
hope this helps.pic's isnt brilliant:-
[img]
[/img]
Old Feb 23, 2006 | 07:39 PM
jayRS's Avatar
jayRS
PM me your email address mate, ill send ya some pic's of a wiring diagram
Old Feb 23, 2006 | 07:55 PM
FULLBORE's Avatar
FULLBORE
pm sent mate. cheers
Old Feb 23, 2006 | 08:17 PM
jayRS's Avatar
jayRS
dunno who to mate as nothing has arrived in my in box, and its only 20% full
Old Feb 23, 2006 | 08:20 PM
FULLBORE's Avatar
FULLBORE
how about now???
Old Feb 23, 2006 | 08:25 PM
jayRS's Avatar
jayRS
yep got it now, ive added you to my msn, can send it over that way if ya want
Old Feb 23, 2006 | 08:56 PM
FULLBORE's Avatar
FULLBORE
dont mind mate.whateva is easiest for you
Old Feb 23, 2006 | 09:25 PM
jayRS's Avatar
jayRS
ya not online mate
Old Feb 24, 2006 | 12:04 PM
jrs's Avatar
jrs
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
